Parasitisme et structuration génétique et spatiale : exemple chez le mouflon méditerranéen, Ovis gmelini musimon x Ovis sp - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2018
Parasitism and spatial genetic structure : Example of the Mediteranean Mouflon, Ovis gmelini musimon x Ovis sp.
Using as a case study the Mediterranean mouflon (Ovis gmelini musimon × Ovis sp.), we aimed at better understanding how are linked genetic diversity, individual behaviour, gene flows and parasitic dynamic. Using population and landscape genetics approaches, we showed that the spatial genetic structure of the studied population was determined by its introduction history, its socio-spatial structure and the landscape in which it evolves. Given the impact of these elements on mouflon gene flow, we expected them to also determine parasite transmission in the population. Our results nevertheless evidenced that parasite are better dispersed than mouflon genes. Finally, we showed that host resistance to parasites depends on neutral and adaptive genetic diversity, and more specifically on heterozygosity at a immunity-linked locus. Our results precisely describe genetic variability spatial distribution and its link with sanitary risks in the studied population, bringing crucial information for wild sheep population management and conservation in the current context of global changes and disease reemergence.
En utilisant comme cas d’étude le mouflon Méditerranéen (Ovis gmelini musimon × Ovis sp.), les objectifs de cette thèse étaient de mieux comprendre comment sont liés diversité génétique, comportement des individus, flux de gènes et dynamique parasitaire. Au travers d’approches de génétique des populations et de génétique du paysage, nous avons pu mettre en évidence que la structure génétique spatiale de la population étudiée était impactée par son histoire d’introduction, sa structure socio-spatiale et le paysage dans lequel elle évolue. Etant donné l’impact de ces divers éléments sur les flux de gènes des mouflons, nous nous attendions à ce qu’ils déterminent également les flux de parasites dans la population. Nos résultats ont, au contraire, révélé que les parasites circulent mieux que les gènes de mouflons dans la population. Enfin, nous avons montré que les capacités de résistance des hôtes face à leurs parasites dépendaient de la diversité génétique neutre et adaptative, notamment de l’hétérozygotie d’un gène lié à l’immunité. Les résultats de ce travail décrivent avec précision la distribution de la variabilité génétique et son lien avec les risques sanitaires dans la population d’étude, apportant ainsi des informations cruciales pour la mise en place de stratégies de gestion et de conservation des populations de mouflons dans le contexte actuel de changements globaux et de réémergences de maladies.
2018_PORTANIER_archivage.pdf (6.06 Mo) Télécharger le fichier
tel-01954652 , version 1 (13-12-2018)
  • HAL Id : tel-01954652 , version 1
Elodie Portanier. Parasitisme et structuration génétique et spatiale : exemple chez le mouflon méditerranéen, Ovis gmelini musimon x Ovis sp. Génétique des populations [q-bio.PE]. Université Montpellier, 2018. Français. ⟨NNT : 2018MONTG038⟩. ⟨tel-01954652⟩
261 Consultations
717 Téléchargements
