Integrated genomics of olfactory neuroblastoma : pathologic and therapeutic implications
Génomique intégrée des neuroblastomes olfactifs : implications anatomopathologiques et thérapeutiques
Olfactory neuroblastomas (ONBs) are rare tumors arising in the skull base. Classification tools are poor, notably; no molecular classification of ONB has been reported. Literature data about their cell of origin, the existence of molecular therapeutic targets or their immune environment being scarce, the biology of these tumors is still poorly understood. Our work was based on exome, transcriptome and methylome analysis, but also on histopathological and immune characteristics of a series of 59 clinically well annotated ONBs. We highlighted 2 sub-types of ONB showing different expression and clinicopathologic patterns. The neural type is a well differentiated, poorly aggressive tumor which shows neurons characteristics and shares phenotypic similarities with olfactory neuron progenitors. The basal type is a less differentiated tumor, displaying an aggressive phenotype, with embryonic phenotypical characteristics, which shares similarities with basal renewing cells of the olfactory epithelium. We showed that the mutational load was higher in basal tumors, with notably recurrent IDH2 R172 mutations associated with a CpG Island Methylator Phenotype (CIMP). We also showed that basal type ONBs were infiltrated by a greater number of T cells with, in some cases, a higher expression of immune checkpoints and immunosuppressive factors. This work paves the way towards a new molecular classification which will allow a better stratification of patients and will open the field of new therapeutic strategies for this rare tumor.
Les neuroblastomes olfactifs (NBOs) sont des tumeurs rares de la base du crâne. Les outils de classification de ces tumeurs sont insuffisants, il n’existe notamment aucune classification moléculaire des NBO. La biologie de ses tumeurs est mal connue. Nos travaux se sont appuyés sur l’analyse des exomes, du transcriptome, du méthylome et des caractéristiques histopathologiques et immunitaires d’une série de 59 NBOs bien annotés cliniquement. Nous avons mis en évidence l’existence de 2 sous-types de NBO présentant un profil d’expression et un profil anatomo-clinique différent. Le type neural, correspond à une tumeur bien différenciée, peu agressive, présentant des caractéristiques plutôt neuronales et partageant des caractéristiques phénotypiques avec les progéniteurs directs de neurones olfactifs. Le type basal correspond à une tumeur moins différenciée, plus agressive, ayant des caractéristiques plutôt embryonnaires, partageant des caractéristiques phénotypiques avec les cellules basales de renouvellement de l’épithélium olfactif. Nous avons mis en évidence que la charge mutationnelle était plus élevée dans le type basal, avec notamment des mutations IDH2 R172 récurrentes, associées à un phénotype CpG Island Methylator (CIMP). Nous avons également montré que les NBOs de type basal étaient infiltrés par un nombre plus important de lymphocytes T avec, dans certaines tumeurs, une expression plus marquée de checkpoints immunitaires et de facteurs immunosuppresseurs. Ce travail ouvre la perspective d’une classification moléculaire permettant de mieux stratifier les patients et ouvre également le champ de nouvelles stratégies thérapeutiques dans ces tumeurs rares.
