Time warp invariant sparse coding and dictionary learning for time series classification and clustering - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2018
Représentations parcimonieuses et apprentissage de dictionnaires pour la classification et le clustering de séries temporelles
Learning dictionary for sparse representing time series is an important issue to extract latent temporal features, reveal salient primitives and sparsely represent complex temporal data. This thesis addresses the sparse coding and dictionary learning problem for time series classification and clustering under time warp. For that, we propose a time warp invariant sparse coding and dictionary learning framework where both input samples and atoms define time series of different lengths that involve varying delays.In the first part, we formalize an L0 sparse coding problem and propose a time warp invariant orthogonal matching pursuit based on a new cosine maximization time warp operator. For the dictionary learning stage, a non linear time warp invariant kSVD (TWI-kSVD) is proposed. Thanks to a rotation transformation between each atom and its sibling atoms, a singular value decomposition is used to jointly approximate the coefficients and update the dictionary, similar to the standard kSVD. In the second part, a time warp invariant dictionary learning for time series clustering is formalized and a gradient descent solution is proposed.The proposed methods are confronted to major shift invariant, convolved and kernel dictionary learning methods on several public and real temporal data. The conducted experiments show the potential of the proposed frameworks to efficiently sparse represent, classify and cluster time series under time warp.
L'apprentissage de dictionnaires à partir de données temporelles est un problème fondamental pour l’extraction de caractéristiques temporelles latentes, la révélation de primitives saillantes et la représentation de données temporelles complexes. Cette thèse porte sur l’apprentissage de dictionnaires pour la représentation parcimonieuse de séries temporelles. On s’intéresse à l’apprentissage de représentations pour la reconstruction, la classification et le clustering de séries temporelles sous des transformations de distortions temporelles. Nous proposons de nouveaux modèles invariants aux distortions temporelles.La première partie du travail porte sur l’apprentissage de dictionnaire pour des tâches de reconstruction et de classification de séries temporelles. Nous avons proposé un modèle TWI-OMP (Time-Warp Invariant Orthogonal Matching Pursuit) invariant aux distorsions temporelles, basé sur un opérateur de maximisation du cosinus entre des séries temporelles. Nous avons ensuite introduit le concept d’atomes jumelés (sibling atomes) et avons proposé une approche d’apprentissage de dictionnaires TWI-kSVD étendant la méthode kSVD à des séries temporelles.Dans la seconde partie du travail, nous nous sommes intéressés à l’apprentissage de dictionnaires pour le clustering de séries temporelles. Nous avons proposé une formalisation du problème et une solution TWI-DLCLUST par descente de gradient.Les modèles proposés sont évalués au travers plusieurs jeux de données publiques et réelles puis comparés aux approches majeures de l’état de l’art. Les expériences conduites et les résultats obtenus montrent l’intérêt des modèles d’apprentissage de représentations proposés pour la classification et le clustering de séries temporelles.
VARASTEH_YAZDI_2018_diffusion.pdf (2.41 Mo) Télécharger le fichier
tel-02069011 , version 1 (15-03-2019)
  • HAL Id : tel-02069011 , version 1
Saeed Varasteh Yazdi. Time warp invariant sparse coding and dictionary learning for time series classification and clustering. Machine Learning [cs.LG]. Université Grenoble Alpes, 2018. English. ⟨NNT : 2018GREAM062⟩. ⟨tel-02069011⟩
293 Consultations
668 Téléchargements
