Software-level analysis and optimization to mitigate the cost of write operations on non-volatile memories - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2018
Analyse logicielle et optimisation pour réduire le coût des opérations d'écriture sur les mémoires non volatiles
Traditional memories such as SRAM, DRAM and Flash have faced during the last years, critical challenges related to what modern computing systems required: high performance, high storage density and low power. As the number of CMOS transistors is increasing, the leakage power consumption becomes a critical issue for energy-efficient systems. SRAM and DRAM consume too much energy and have low density and Flash memories have a limited write endurance. Therefore, these technologies can no longer ensure the needs in both embedded and high-performance computing domains. The future memory systems must respect the energy and performance requirements. Since Non Volatile Memories (NVMs) appeared, many studies have shown prominent features where such technologies can be a potential replacement of the conventional memories used on-chip and off-chip. NVMs have important qualities in storage density, scalability, leakage power, access performance and write endurance. Nevertheless, there are still some critical drawbacks of these new technologies. The main drawback is the cost of write operations in terms of latency and energy consumption. We propose a compiler-level optimization that reduces the number of write operations by elimination the execution of redundant stores, called silent stores. A store is silent if it’s writing in a memory address the same value that is already stored at this address. The LLVM-based optimization eliminates the identified silent stores in a program by not executing them. Furthermore, the cost of a write operation is highly dependent on the used NVM and its non-volatility called retention time; when the retention time is high then the latency and the energetic cost of a write operation are considerably high and vice versa. Based on that, we propose an approach applicable in a multi- bank NVM where each bank is designed with a specific retention time. We analysis a program and we compute the worst-case lifetime of a store instruction to allocate data to the most appropriate NVM bank.
La consommation énergétique est devenue un défi majeur dans les domaines de l'informatique embarquée et haute performance. Différentes approches ont été étudiées pour résoudre ce problème, entre autres, la gestion du système pendant son exécution, les systèmes multicœurs hétérogènes et la gestion de la consommation au niveau des périphériques. Cette étude cible les technologies de mémoire par le biais de mémoires non volatiles (NVMs) émergentes, qui présentent intrinsèquement une consommation statique quasi nulle. Cela permet de réduire la consommation énergétique statique, qui tend à devenir dominante dans les systèmes modernes. L'utilisation des NVMs dans la hiérarchie de la mémoire se fait cependant au prix d'opérations d'écriture coûteuses en termes de latence et d'énergie. Dans un premier temps, nous proposons une approche de compilation pour atténuer l'impact des opérations d'écriture lors de l'intégration de STT-RAM dans la mémoire cache. Une optimisation qui vise à réduire le nombre d'opérations d'écritures est implémentée en utilisant LLVM afin de réduire ce qu'on appelle les silent stores, c'est-à-dire les instances d'instructions d'écriture qui écrivent dans un emplacement mémoire une valeur qui s'y trouve déjà. Dans un second temps, nous proposons une approche qui s'appuie sur l'analyse des programmes pour estimer des pire temps d'exécution partiaux, dénommés δ-WCET. À partir de l'analyse des programmes, δ-WCETs sont déterminés et utilisés pour allouer en toute sécurité des données aux bancs de mémoire NVM avec des temps de rétention des données variables. L'analyse δ-WCET calcule le WCET entre deux endroits quelconques dans un programme, comme entre deux blocs de base ou deux instructions. Ensuite, les pires durées de vie des variables peuvent être déterminées et utilisées pour décider l'affectation des variables aux bancs de mémoire les plus appropriées.
BOUZIANE_Rabab.pdf (2.91 Mo) Télécharger le fichier
tel-02089718 , version 1 (04-04-2019)
  • HAL Id : tel-02089718 , version 1
Rabab Bouziane. Software-level analysis and optimization to mitigate the cost of write operations on non-volatile memories. Performance [cs.PF]. Université de Rennes, 2018. English. ⟨NNT : 2018REN1S073⟩. ⟨tel-02089718⟩
291 Consultations
646 Téléchargements
