L'organisation 3D des chromosomes synthétiques de levure - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2018
3D organisation of synthetic yeast chromosomes
The international project Sc2.0 started 10 years ago by the Pr. Jef Boeke aims to build a fully synthetic genome of S. cerevisiae which increases the genome stability by removing all repeated sequences (tRNA, transposable elements, etc.), and implements SCRaMbLE (for Synthetic Chromosome Rearrangement and Modification by LoxP-mediated Evolution), an inducible, high-throughput chromosome rearrangement system. This design is highly conservative with respect to gene content, the deletion of several classes of repeated sequences and the introduction of thousands of designer changes. However, it may affect genome organization and potentially alter cellular functions. To determine wether those modifications affected the three-dimensional conformation of synthetic chromosmes, we investigated it using chromosomes conformation capture coupled to second generation sequencing method (Hi-C). Currently, eight synthetic chromosomes (synI, synII, synIII, synV, synVI, synIX-R, synX et synXII) have been fully assembled. Using these strains we observed that the large-scale genomic organization is globally unaffected by the presence of synthetic chromosome(s). Two exceptions are synIII, which lacks the silent mating-type cassettes, and synXII, specifically when the ribosomal DNA is moved to another chromosome. We also exploited the contact maps to detect rearrangements induced in these SCRaMbLE strains.
Le projet international de synthèse des chromosomes de S. cerevisiae (projet Sc2.0) a débuté il y a une dizaine d'années en suivant des principes établis par le Pr. Jef Boeke. Les chromosomes synthétiques ont été conçus pour augmenter la stabilité du génome en supprimant toutes les séquences répétées (ARNt, éléments transposables...), tout en y ajoutant un système d'évolution inductible dépendant du système Cré/LoxP (système SCRaMbLE), permettant de générer rapidement des réarrangements chromosomiques. Bien que le design du projet Sc2.0 soit très conservateur en ce qui concerne le contenu des gènes, la suppression de plusieurs classes de séquences répétées peut affecter l'organisation du génome et potentiellement altérer les fonctions cellulaires. En utilisant la méthode de capture de conformation de chromosome couplée au séquençage de seconde génération (Hi-C), mon objectif a été de caractériser l'organisation 3D des génomes des souches synthétiques et évoluées. À ce jour, huit chromosomes (syn I, II, III, V, VI, IX-R, X et XII) ont été entièrement assemblés séparément. En utilisant les souches contenant un ou plusieurs de ces chromosomes, nous avons pu montrer que leur organisation génomique n'est globalement pas affectée par leur présence. Quelques exceptions subsistent, avec synIII dont les cassettes HML et HMR ont été retirées, et synXII d'où l'ADNr a été déplacé sur un autre chromosome. À ce stade, nous concluons que l'ADN répétitif dispersé ne conduit pas la conformation moyenne globale du génome de S. cerevisiae. Nous avons aussi exploité les cartes de contacts pour identifier les réarrangements dans les souches SCRaMbLE.
2018SORUS034.pdf (49.86 Mo) Télécharger le fichier
tel-02111002 , version 1 (25-04-2019)
  • HAL Id : tel-02111002 , version 1
Guillaume Mercy. L'organisation 3D des chromosomes synthétiques de levure. Génomique, Transcriptomique et Protéomique [q-bio.GN]. Sorbonne Université, 2018. Français. ⟨NNT : 2018SORUS034⟩. ⟨tel-02111002⟩
343 Consultations
45 Téléchargements
