Au coeur du contrôle de l’immunité humorale : (re)définition, mode d’action et répertoire des lymphocytes T folliculaires régulateurs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2017
The immune humoral response offers the organism an efficient protection through the production of antibodies following an immune stimulation
The immune humoral response offers the organism an efficient protection through the production of antibodies following an immune stimulation. Follicular regulatory T cell (Tfr) is an essential subset in the control of humoral immunity. These cells share with conventional regulatory T (Treg) cells regulatory functions and should play a major role in the control of antibody production following stimulation. As T follicular helper (Tfh) cells help is essential in the differentiation of B cell into antibody-producing plasma cells, one of the possible mechanisms of Tfr’s control could be the limitation of the Tfh cells’ help to the B cells. As a consequence of the non-response of Tfr cells to interleukin (IL)-2, we thoroughly revealed the CD25- phenotype of Tfr cells thus redefining the subset. This stringently-selected population allowed a fine-tuned characterization of Tfr cells and the discovery of an IL-1β axis regulating the germinal center responses. The dual regulation of T cells in secondary lymphoid organs, one between Treg and Teff cells regulated by IL-2 outside germinal centers and the other between Tfh and Tfr cells regulated by IL-1 inside GCs brought us to question the origin and specificity of Tfr cells. We partially answered this with a high-resolution analysis of these populations’ repertoires. We highlighted a similarity in the distributions and global characteristics of the follicular cells’ repertoires regardless their regulatory (Tfr) or not (Tfh) phenotype. We also brought out the major sharing between Treg and Tfr repertoires underpinning the hypothesis of a common origin for these populations. This work has disclosed important aspects of Tfr cells’ biology, a fundamental subset in the control of humoral immune responses. It opens many perspectives including the control of antibody production, negatively in the context of autoimmune diseases or its positive exploitation to enhance vaccine efficacy
La réponse immunitaire humorale désigne l’ensemble des processus menant à la production d’anticorps suite à une stimulation du système immunitaire. Les lymphocytes T folliculaires régulateurs (Tfr) forment une population essentielle dans le contrôle de l’immunité humorale. Dotés de fonctions régulatrices comme les lymphocytes T régulateurs conventionnels (Treg), les Tfr joueraient un rôle majeur dans les mécanismes de régulation de la production d’anticorps suite à une stimulation. Ils pourraient, par exemple, contrôler l’aide apportée par les lymphocytes T folliculaires helpers (Tfh) aux cellules B leur permettant de se différencier en plasmocytes producteurs d’anticorps dans une structure hautement spécialisée appelée centre germinatif (CG). Suite au constat de la non-réponse des Tfr à l’interleukine (IL)-2, nous avons observé l’absence d’expression de la sous-unité du récepteur à l’IL-2 (CD25) sur ces cellules et ainsi donné de nouvelles bases à la caractérisation phénotypique des Tfr. Cette redéfinition restrictive de la population cellulaire a permis une description plus approfondie de ces cellules et la découverte d’un axe de régulation du CG dépendant de l’IL-1ß. La dualité de régulations observée entre d’une part l’axe Treg - lymphocytes T effecteurs contrôlé par l’IL-2 en dehors du CG et d’autre part l’axe Tfr - Tfh contrôlé par l’IL-1ß dans le CG nous a amenés à nous poser la question de l’origine et de la spécificité des Tfr en partie élucidée par une analyse du répertoire de ces populations. Nous avons mis en évidence une similarité en matière de distribution et caractéristiques globales des répertoires des cellules folliculaires qu’elles soient régulatrices (Tfr) ou non (Tfh). Il est également apparu une proximité de spécificités entre le répertoire des Treg et des Tfr confortant l’hypothèse d’une origine commune de ces deux populations. Ce travail de thèse a permis la découverte d’éléments importants de la biologie des Tfr, population impliquée dans le contrôle des régulations humorales. Il ouvre des perspectives relatives au contrôle de la production d’anticorps tant sa limitation - dans le contexte de maladies auto-immunes - que son exploitation dans le développement de stratégies vaccinales.
va_Ritvo_Paul-Gydeon.pdf (6.66 Mo) Télécharger le fichier
tel-02111720 , version 1 (26-04-2019)
  • HAL Id : tel-02111720 , version 1
Paul-Gydéon Ritvo. Au coeur du contrôle de l’immunité humorale : (re)définition, mode d’action et répertoire des lymphocytes T folliculaires régulateurs. Immunologie. Université Sorbonne Paris Cité, 2017. Français. ⟨NNT : 2017USPCB025⟩. ⟨tel-02111720⟩
1712 Consultations
589 Téléchargements
