Sociologie de la connaissance du chiisme dans l'espace des savoirs sur l'Iran en France (1947-2010) - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2018
The sociology of knowledge of Shiism in the space of knowledge on Iran in France (1947-2010)
Since the establishment of renewed Iranian Studies in Post-War period, the academic study of Iran has been growing abundantly in France. In this scientific space of knowledge, the question of “shi’isme” has been evoked prominently through philosophical and spiritual patterns since it became more controversial after the revolution of 1979 and the revival of “shi’isme” as an ideological mean of defying the imperial regime. This led to an epistemological and institutional rupture related to different theoretical and methodological patterns within disciplines and thought systems associated with the construction of “shi’isme” as an object of scientific enquiries. The rise of intellectual controversies between spiritual and historicized frameworks that oriented the production of discourses on “shi’isme” challenges the scientific and epistemological patterns of knowledge construction, as well as ideological and socio-political ones. This study attempts to provide a constructivist approach to the advent and the evolution of scientific discourses on “shi’isme” in France from 1947 to 2010, through a socio-historical viewpoint of the sociology of knowledge. Institutional patterns, epistemological criteria and sociological components will be put together to illustrate a comprehensive mapping of discourse structuration on “shi’isme” in the French space of knowledge on Iran.
Dans l’espace des savoirs sur l’Iran, les énoncés concernant sa dimension religieuse ne sont pas rares. Au contraire, cet espace déborde de travaux qui ont, soit la religion pour objet principal d’analyse, soit une place primordiale pour la religion en en faisant le facteur par excellence de la compréhension de la société, de la culture et de la politique iraniennes. Reconnu en tant qu’une tradition spirituelle, ésotérique et mystique de l’islam dans la période de l’institutionnalisation des études iraniennes, en France, le chiisme fait objet de controverses intellectuelles après sa mise en action par les révolutionnaires de 1978-1979 et l’instauration de la République islamique d’Iran. Dépassant les cadres interprétatifs sclérosés de la connaissance du chiisme par les philosophes, les spécialistes des sciences religieuses et ceux de la civilisation iranienne, ce sont désormais les praticiens en sciences sociales qui prennent le relais pour la formation des discours scientifiques à ce sujet. Cette bifurcation d’objet, liée autant aux faits qu’aux orientations épistémiques, didactiques et idéologiques, va de pair avec l’agir de la conjoncture sociopolitique sur les conditions de possibilité du savoir pour que la problématisation de la question du chiisme constitue un éventail difficile et imprévisible. En partant d’une approche constructiviste, cette thèse entend donner à voir les composants scientifiques mais aussi extrascientifiques qui orientent la problématisation du chiisme dans l’espace des savoirs sur l’Iran en France de 1947 à 2010.
Sociologie
2018PSLEP002_archivage.pdf (22.95 Mo) Télécharger le fichier
tel-02133673 , version 1 (19-05-2019)
  • HAL Id : tel-02133673 , version 1
Morvarid Ayaz. Sociologie de la connaissance du chiisme dans l'espace des savoirs sur l'Iran en France (1947-2010). Sociologie. Université Paris sciences et lettres, 2018. Français. ⟨NNT : 2018PSLEP002⟩. ⟨tel-02133673⟩
844 Consultations
136 Téléchargements
