Development of educational strategies for patients with knee osteoarthritis in spa therapy
Développement de stratégies éducatives auprès de patients souffrant de gonarthrose, en milieu thermal
The aim of this work was to develop educational strategies in association with spa therapy treatment for patients with knee osteoarthritis, with a goal not only of clinical, psychological but also of improvement of the level of physical activity. A total of 745 patients with knee osteoarthritis were recruited from the 9 members thermal spa of the Innovatherm Cluster and distributed among the 3 studies building this project. The first study looked at the qualitative analysis of facilitators and barriers to physical activity. The second study on the level of physical activity and the analysis of the factors influencing the practice. The third study evaluated the effects of a self-management exercise education program in spa therapy resort. Analysis of the results of studies 1 and 2 showed the level of physical activity was significantly dependent on certain anthropometric data (gender, BMI, obesity), extrinsic factors (life situation, family situation) and intrinsic factors (motivation, well-being, self-efficacy, fatigue, aging, fear of aggravating knee osteoarthritis). Study 3 showed that spa treatment associated with or without self-management exercise program significantly increases the physical activity level, with medium effect size 0.53 [0.28; 0.77] at 3 months. Exercise education have a significant beneficial effect between groups in favor of the intervention group on anxiety, depression and fears and beliefs. These studies confirm the impact of spa therapy treatment on the clinical parameters of osteoarthritis and provide new data on the increase of the physical activity level and argues in favor of the cognitive and psychological effect of the self management exercise program.
L’objectif de ce travail était de développer des stratégies éducatives en association avec une cure thermale à destination de patients porteurs de gonarthrose, avec un objectif non seulement d’efficacité clinique et psychologique mais aussi d’amélioration du niveau d’activité physique. Au total, 745 patients souffrants de gonarthrose ont été recrutés sur les 9 stations thermales membre du Cluster Innovatherm et répartis dans les 3 études composant ce projet. La première étude porte sur l’analyse qualitative des freins et des leviers à la pratique d’activité physique. La seconde étude a mesuré le niveau d’activité physique et analysé les facteurs influençant la régularité de la pratique. La troisième étude a évalué les effets d’un programme d’éducation à l’exercice en milieu thermal. L’analyse des résultats des 2 premières études a montré que le niveau d’activité physique des gonarthrosiques était significativement dépendant de certaines données sociodémographiques, anthropométriques (genre, indice de masse corporelle, obésité), de facteurs extrinsèques (lieu de vie, situation familiale) et de facteurs intrinsèques (motivation, bien être, « self-efficacy », fatigue, vieillissement, peur d’aggraver la gonarthrose). La troisième étude a montré que le traitement thermal associé ou non aux ateliers d’éducation à l’exercice permetait d’augmenter significativement le niveau d’activité physique, avec un effet taille moyen de 0.53 [0.28;0.77] à 3 mois. Les ateliers d’éducation à l’exercice ont un effet bénéfique significatif sur l’anxiété, la dépression et les peurs et croyances (sous item médecin du KOFBeQ), à 3 mois. Ces études confirment l’impact du traitement thermal sur les paramètres cliniques de la gonarthrose et fournissent de nouvelles données concernant ce traitement sur l’évolution du niveau d’activité physique. Cette étude argumente en faveur de l’effet cognitif et psychologique du programme d’éducation à l’exercice.
