Johnson-type homomorphisms for surfaces and the universal perturbative invariant of 3-manifolds - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2019
Homomorphismes de type Johnson pour les surfaces et invariant perturbatif universel des variétés de dimension trois
Let Σ be a compact oriented surface with one boundary component and let M denote the mapping class group of Σ. By considering the action of M on the fundamental group of Σ it is possible to define different filtrations of M together with some homomorphisms on each term of the filtrations. The aim of this thesis is twofold. First, we study two filtrations of M : the « Johnson-Levine filtration » introduced by Levine and « the alternative Johsnon filtration » introduced recently by Habiro and Massuyeau. The definition of both filtrations involve a handlebody bounded by Σ. We refer to these filtrations as « Johnson-type filtrations » and the corresponding homomorphisms are referred to as « Johnson-type homomorphisms » by their analogy with the original Johnson filtration and the usual Johnson homomorphisms. We provide a comparison of the Johnson filtration with the Johnson-Levine filtration at the level of the monoid of homology cobordisms of Σ. We also provide a comparison of the alternative Johnson filtration with the Johnson-Levine filtration and the Johnson filtration at the level of the mapping class group. Secondly, we study the relationship between the « Johnson-type homomorphisms » and the functorial extension of the universal perturbative invariant of 3-manifolds (the Le-Murakami-Ohtsuki invariant or LMO invariant). This functorial extension is called the LMO functor and it takes values in a category of diagrams. We prove that the « Johnson-type homomorphisms » can be read in the tree reduction of the LMO functor. In particular, this provides a new reading grid of the tree reduction of the LMO functor.
Soit Σ une surface compacte connexe orientée avec une seule composante du bord. Notons par M le groupe d’homéotopie de Σ. En considérant l’action de M sur le groupe fondamental de Σ, il est possible de définir différentes filtrations de M ainsi que des homomorphismes sur chaque terme de ces filtrations. Le but de cette thèse es double. En premier lieu, nous étudions deux filtrations de M : la « filtration de Johnson-Levine » introduite par Levine et la « filtration de Johnson alternative » introduite recémment par Habiro et Massuyeau. Les définitions de ces deux filtrations prennent en compte un corps en anses bordé par la surface. Nous nous référons à ces filtrations comme « filtrations de type Johson » et les homomorphismes correspondants sont appelés « homomorphismes de type Johnson » par leur analogie avec la filtration de Johnson originale et les homomorphismes de Johnson usuels. Nous donnons une comparaison de la filtration de Johnson avec la filtration de Johnson-Levine au niveau du monoïde des cobordismes d’homologie de Σ. Nous donnons également une comparaison entre la filtration de Johnson alternative, la filtration Johnson-Levine et la filtration de Johnson au niveau du groupe d’homéotopie. Deuxièmement, nous étudions la relation entre les « homomorphismes de type Johnson » et l’extension fonctorielle de l’invariant perturbatif universel des variétés de dimension trois (l’invariant de Le-Murakami-Ohtsuki ou invariant LMO). Cette extension fonctorielle s'appelle le foncteur LMO et il prend ses valeurs dans une catégorie de diagrammes. Nous démontrons que les « homomorphismes de type Johnson » peuvent être lus dans la réduction arborée du foncteur LMO. En particulier, cela fournit une nouvelle grille de lecture de la réduction arborée du foncteur LMO.
VERA_ARBOLEDA_Anderson_2019_ED269.pdf (6.89 Mo) Télécharger le fichier
tel-02145110 , version 1 (01-06-2019)
tel-02145110 , version 2 (30-06-2019)
tel-02145110 , version 3 (16-10-2019)
  • HAL Id : tel-02145110 , version 2
Anderson Vera. Johnson-type homomorphisms for surfaces and the universal perturbative invariant of 3-manifolds. Geometric Topology [math.GT]. Université de Strasbourg, 2019. English. ⟨NNT : ⟩. ⟨tel-02145110v2⟩
397 Consultations
172 Téléchargements
