Optimisation du traitement du cancer du sein Triple-Négatif : développement des modèles de culture cellulaire en trois dimensions, efficacité de l'Olaparib (anti-PARP1) en combinaison avec la radiothérapie et chimiorésistance instaurée par les protéines Multi Drug Résistance - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2018
Optimization of triple-negative breast cancer treatment : development of three-dimensional cell culture models, efficacy of Olaparib (anti-PARP1) in combination with radiotherapy and chemoresistance introduced by "Multi Drug Resistance" proteins
Breast cancer is a very complex and heterogeneous disease. Among the different molecular subtypes, Triple-Negative (TN) breast cancers are particularly aggressive and of poor prognosis. TN tumours are characterized by a lack of estrogen receptors expression (ER), progesterone receptors expression (PR), the absence of Human Epidermal growth factor receptor 2 overexpression (HER2) of the frequent mutations on BRCA1 / 2 genes ("BRCAness" phenotype). In the absence of effective targeted therapies, many targeted therapies including poly-ADP-ribose polymerase inhibitors (anti-PARPs) are currently under development in preclinical and clinical studies. Based on the synthetic lethality concept, the anti-PARPs specifically target the BRCAness properties of TN tumors. In this context, these works were focused on the development of diagnostic tools for the optimization of TN tumours treatment with anti-PARPs. For this, firstly, 3D cell cultures formed with the Liquid Overlay technique as well as associated cytotoxicity tests were developed, from the TN breast cancer cell lines MDA-MB-231 and SUM1315. These two spheroid models were then optimized and standardized in a synthetic culture medium called OPTIPASS (BIOPASS). Secondly, the efficacy of a co-treatment combining anti-PARP1 Olaparib at low and high doses and fractioned radiotherapy (5x2 Gy) was analyzed on the two cell lines MDA-MB-231 and SUM1315 cultured in 2D and 3D conditions. These experiments clearly demonstrated a potentiating effect of Olaparib on radiotherapy (i) in presence of low doses of this anti-PARP (5 μM or inferior) (ii) at long term and (iii) in presence of the maximum fractionation (5x2 Gy). In addition, these two TN cell lines showed a heterogeneous sensitivity to the co-treatment. Thus, an in silico transcriptomic analysis revealed very different profiles of these highly metastatic and highly aggressive cell lines. Notably, the SUM1315 cell line presented a neuronal commitment, suggesting its cerebral metastatic origin. These promising results could open up new perspectives for the treatment of TN tumours brain metastases, which are very common in this subtype. Thirdly, in order to better characterize the mode of action of Olaparib on these spheroid models, a fluorescent derivative of Olaparib, Ola-FL, was synthesized and characterized. The analysis of Ola-FL penetration and distribution in MDA-MB-231 and SUM1315 spheroids showed a rapid and homogeneous distribution of the compound as well as its persistence after 3h of incubation, in all the depth of the spheroids and especially in the central hypoxic zones. Finally, the analysis of the co-expression of two major Multidrug Resistance (MDR) pumps, MRP7 and P-gp after the treatment of the two TN lines with Olaparib, revealed on 2D cultures, a relay type expression of the MRP7 and the P-gp. On spheroids treated with a low dose of Olaparib art long term (10 days), a basal expression of MRP7 and an overexpression of P-gp were detected in the peripheral residual cells of the spheroids. These results clearly highlighted the involvement of these efflux pumps in Olaparib resistance mechanisms, in these aggressive tumors. All the results resulting from the modeling of the action of Olaparib on MDA-MB-231 and SUM1315 spheroids suggest its greater efficacy at low dose and at long-term, especially in the hypoxic zones of the spheroids. This parameter might be probably at the origin of its potentiating effect with radiotherapy.
Le cancer du sein est une maladie complexe et difficile à caractériser. Parmi les différents sous-types moléculaires, les tumeurs du sein Triple-Négatives (TN) sont particulièrement agressives et de mauvais pronostic. Elles sont caractérisées par une absence d’expression des récepteurs aux œstrogènes (ER), à la progestérone (PR), l’absence de surexpression du récepteur Human Epidermal growth factor 2 (HER2) et de fréquentes mutations sur les gènes BRCA1/2 (profil « BRCAness »). En absence de thérapies ciblées efficaces, de nombreux traitements ciblés notamment les inhibiteurs de poly-ADP-ribose polymérases (anti-PARPs) sont actuellement en cours de développement, en recherche préclinique et clinique. Basés sur le principe de létalité synthétique, les anti-PARPs ciblent les propriétés BRCAness des tumeurs TN. Dans ce contexte, ces travaux de recherche ont été orientés sur le développement d’outils diagnostics afin d’optimiser l’efficacité des anti-PARPs sur des tumeurs TN. Pour ce faire, dans un premier temps, des cultures cellulaires en 3D via la technique Liquid Overlay ainsi que des tests de cytotoxicités associés ont été développés, à partir des lignées cellulaires MDA-MB-231 et SUM1315 de phénotype TN. Ces deux modèles de sphéroïdes ont ensuite été optimisés/normalisés dans un milieu de culture synthétique intitulé OPTIPASS (BIOPASS). Dans un deuxième temps, l’efficacité d’un co-traitement combinant l’anti-PARP1 Olaparib à faibles et à fortes doses et la radiothérapie fractionnée (5x2 Gy) a été modélisée sur les deux lignées MDA-MB-231 et SUM1315, en conditions 2D et 3D. Ces expériences ont clairement mis en évidence un effet potentialisateur de l’Olaparib sur la radiothérapie (i) en présence de faibles doses de cet anti-PARP (5 µM ou inférieur) (ii) à long terme et (iii) en présence d’un fractionnement maximum (5x2 Gy). De plus, les lignées tumorales TN étudiées présentaient des différences de sensibilité vis-à-vis du co-traitement. Ainsi, une analyse transcriptomique in silico a mis en évidence des profils très différents de ces lignées hautement métastatiques et très agressives. Notamment, la lignée SUM1315 semblait présenter un engagement neuronal, suggérant son origine métastatique cérébrale. Ces résultats encourageants pourraient ouvrir de nouvelles perspectives pour le traitement des métastases cérébrales de tumeurs mammaires TN, très fréquentes chez ce sous-type. Dans un troisième temps, afin de mieux caractériser le mode d’action de l’Olaparib sur ces modèles de sphéroïdes, un dérivé fluorescent de l’Olaparib, l’Ola-FL, a été synthétisé et caractérisé. L’analyse de la pénétration et de la distribution de l’Ola-FL au sein des sphéroïdes MDA-MB-231 et SUM1315 a mis en évidence une distribution rapide et homogène du composé ainsi que sa persistance après 3h d’incubation, dans toute la profondeur des sphéroïdes et notamment dans les zones hypoxiques centrales. Enfin, l’analyse de la co-expression de deux pompes Multidrug Resistance (MDR) majeures, la MRP7 et la P-gp après le traitement des deux lignées TN avec l’Olaparib, a mis en évidence sur les cultures 2D, une expression de type relai de la MRP7 et la P-gp. Sur les sphéroïdes traités avec une faible dose d’Olaparib à long terme, une expression basale de la MRP7 et une surexpression de la P-gp ont été détectées, au sein des cellules résiduelles périphériques des sphéroïdes. Ces résultats mettent clairement en évidence l’implication des pompes d’efflux dans les mécanismes de résistances à l’Olaparib, dans ces tumeurs agressives. L’ensemble des résultats issus de la modélisation de l’action de l’Olaparib sur des sphéroïdes MDA-MB-231 et SUM1315 laissent supposer sa plus grande efficacité à faible dose et à long-terme, notamment dans les zones hypoxiques des sphéroïdes, probablement aussi à l’origine de son effet potentialisateur avec la radiothérapie.
2018CLFAS018-DUBOIS.pdf (9.35 Mo) Télécharger le fichier
tel-02166394 , version 1 (26-06-2019)
  • HAL Id : tel-02166394 , version 1
Clémence Dubois. Optimisation du traitement du cancer du sein Triple-Négatif : développement des modèles de culture cellulaire en trois dimensions, efficacité de l'Olaparib (anti-PARP1) en combinaison avec la radiothérapie et chimiorésistance instaurée par les protéines Multi Drug Résistance. Cancer. Université Clermont Auvergne [2017-2020], 2018. Français. ⟨NNT : 2018CLFAS018⟩. ⟨tel-02166394⟩
741 Consultations
628 Téléchargements
