Long term performance of low temperature asphalt pavements containing reclaimed asphalt
Durabilité des enrobés tièdes intégrant des recyclés
Roads are the most widely used mode of transportation in the world, and a country’s development is often measured in terms of its total paved roads mile age. Pavements are an essential part of our social network and asphalt concrete is the main material used for manufacturing them. Currently, the European road network is not much growing anymore and mostly needs only maintenance. In a context of increasing demand of performance and durability of asphalt mixtures, a sustainable, durable and economical conceptionis required. Indeed it could be oriented towards a self sufficient road providing its own raw materials through recycling while limiting the use of energy and other natural resources for its maintenance.The combination of warm mix asphalts (WMA) technologies and high rates of reclaimed asphalt pavements (RAP)appears as a solution to achieve both energy and natural resources savings. But it is still ambiguous in terms of durability. Therefore, an experimental program is set up to show the evolution of the performances of such asphalt concretes with time, highlighting the notion of ageing mostly related to the bituminous fraction. At the bitumen scale, the long term assessment is carried out in particular by applying the δ-method compare with GPC measurements both on model samples with controlled asphaltene content and laboratory aged ones. At the asphalt mixture scale, a comparison studyis carried out between a reference HMA and WMAs with 0%- 50% of RAP submitted to a laboratory ageing procedure. The long term performances of the mixtures are compared by means of complex modulus and fatigue testing. Results show a relation between the evolution of the structure of the bitumen with ageing and the mechanical performances. Short term ageing is less important for warm processes. After ageing, the overall tendencies are similar for all processes.
Les routes sont le moyen de transport le plus utilisé dans le monde et le développement d'un pays est souvent mesuré en termes de kilométrage total des routes revêtues. Les chaussées sont essentielles à notre réseau social et l’enrobé bitumineux est le matériau le plus utilisé pour leur fabrication. À l'heure actuelle, le réseau routier européen n’est plus en forte croissance et nécessite surtout un entretien. Dans un contexte de développement durable de plus en plus exigeant,la route pourrait donc représenter sa propre source d’approvisionnement en tirant parti du recyclage. Elle doit aussi limiter les quantités d’énergies et de ressources naturelles nécessaires à sa propre maintenance.La combinaison des techniques d’enrobés tièdes (WMA) et de taux de recyclage élevés d’agrégats d’enrobés (RAP) apparaît comme une solution permettant d’économiser à la fois l’énergie et les ressources naturelles. Mais sa durabilité doit être éprouvée. Un programme expérimental a donc été mis en place pour montrer l'évolution des performances de ces enrobés bitumineux avec le temps, mettant en évidence la notion de vieillissement essentiellement lié à la fraction bitumineuse. A l'échelle du bitume, l'évaluation à long terme est effectuée notamment en appliquant la δ-méthode et en comparant avec les mesures de masses moléculaires par GPC à la fois sur des échantillons modèles à teneur en asphaltènes controllée et sur des échantillons de laboratoire. A l’échelle de l’enrobé bitumineux, une étude comparative a été réalisée entre un enrobé à chaud traditionnel et des WMAs incluant 0% ou 50% de RAP soumis à une procédure de vieillissement en laboratoire. Les performances à long terme des mélanges sont comparées au moyen d’essais de module complexe et de fatigue.Les résultats montrent une relation entre l’évolution de la structure des bitumes par vieillissement et les performances mécaniques. Le vieillissement à court terme au moment de la fabrication est beaucoup moins marqué pour les procédés tièdes. Après vieillissement à long terme, les tendances générales sont similaires pour tous les procédés.
