Tribological numerical materials for a rail braking system
Matériaux numériques tribologiques pour un système de freinage ferroviaire
The increase of the rail speed imposes the improvement of the braking performances related to the friction materials used in brake pad and brakes shoes. However, wear remains a limiting point in terms of performance but also safety. It has the effect of damaging the materials (mechano-thermal aspects) but also to contaminate the contact between wheel and rail by particles of brake shoes that can electrically isolate it (mechanical-electrical aspects). The method for locating the trains, whose principle is the electrical conduction between wheel and rail, is then compromised.These issues are governed by the different contacts (wheel/rail, wheel/shoes, ...) that fit into the concept of tribological triplets. These are composed of the bodies in contact (first bodies), the interface (third body) and the mechanism that keeps them in contact. In order to understand the phenomena occurring within the contacts, a local multi-physics analysis and a decoupling of the parameters (mechanical, thermal, electrical) are necessary. However, this is difficult to establish experimentally, numerical modeling by discrete elements method is then relevant for these needs.The dynamic flow of a third body consisting of braking particles and the degradation of a real braking material (following imaging methods) are modeled. The results obtained made it possible to understand the competitions existing between physical parameters on the one hand (mechanical, electrical, thermal) and scale parameters on the other hand (local, global). These competitions tend to minimize the electrical resistance when the constituents are in adequate proportion (better electrical conduction between wheel and rail) but also to balance the flows of the tribological track, which leads to protect the materials (controlled wear). In addition, the numerical analyzes made it possible to highlight new parameters related to "spreading" of the third body and to apprehend the key points making it possible to approach a real contact.
L’augmentation de la vitesse ferroviaire impose l’amélioration des performances de freinage liés aux matériaux de friction utilisés dans les freins à disques et à semelles. Cependant, l'usure reste un point limitant en terme de performance mais aussi de sécurité. Elle a pour conséquence de détériorer les matériaux (aspects mécano-thermiques) mais aussi de contaminer le contact entre roue et rail par des particules de semelles de frein pouvant isoler électriquement celui-ci (aspects mécano-électriques). Le procédé permettant de localiser les trains, ayant pour principe la conduction électrique entre roue et rail, est alors compromis.Ces problématiques sont gouvernées par les différents contacts (roue/rail, roue/semelle, ...) qui s'inscrivent dans le concept de triplet tribologique. Un triplet est composé des corps en contact (premiers corps), de l'interface (troisième corps) et du mécanisme qui les maintient en contact. Afin de comprendre les phénomènes se produisant au sein des contacts, une analyse multi-physique locale et un découplage des paramètres (mécaniques, thermiques, électriques) s'avèrent nécessaires. Toutefois, cela est difficile à établir expé- rimentalement, une modélisation numérique par éléments discrets est alors pertinente pour palier à ces besoins.L'écoulement dynamique d'un troisième corps constitué de particules de freinage et la dégradation d'un matériau de freinage réel (suite à des méthodes d'imageries) sont modélisés. Les résultats obtenus ont permis d'appréhender les compétitions existant entre paramètres physiques d'une part (mécanique, électrique, thermique) et paramètres d'éch-elles d'autre part (local, global). Ces compétitions tendent à minimiser la résistance élec- trique lorsque les constituants sont en proportion adéquat (meilleure conduction électrique entre roue et rail) mais aussi à équilibrer les débits du circuit tribologique, ce qui conduit à protéger les matériaux (usure contrôlée). En outre, les analyses numériques ont permis de mettre en évidence de nouveaux paramètres liés à ``l'étalement'' du troisième corps et d'appréhender les points clés permettant de se rapprocher d'un contact réel.
