Etude expérimentale de la multifissuration et de la décohésion de films minces et nanostructures magnétiques sur substrats flexibles : effet sur l'anisotropie magnétique - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2017
Non communiqué
Flexible and stretchable magnetic systems are of increasing interest for the development of electromagnetic devices conformable to non-planar surfaces. In this context, the objective of this thesis is to identify the relationships between irreversible mechanical phenomena (cracking and delamination) at large strains and magnetic properties of thin films of nanometric thicknesses (CoFeB and NiFe alloys) deposited on polymer substrate (Kapton®) by magnetron sputtering. In a first time, tensile tests coupled in situ with atomic force microscopy or electrical resistance measurements were used to study thin film multifissuration and subsequent localized debonding (buckles). These measurements made it possible to highlight areas of macroscopic strains for which each mechanism was predominant. In addition, the adhesion energy could be discussed and estimated from the monitoring of the buckles under applied strain. In a second step, ferromagnetic resonance measurements carried out ex situ made it possible to link the previously identified areas of strains to the evolutions of the magnetic anisotropy of thin films. In addition, a correlation between strain heterogeneities and Gilbert damping coefficient was found. Finally, the magnetomechanical properties of NiFe nanowires arrays have made it possible to highlight the advantage of nanopatterning for these deformable magnetic systems.
Les systèmes magnétiques flexibles et étirables sont d’intérêt croissant pour le développement de dispositifs électromagnétiques conformables aux surfaces non planes. Dans ce contexte, l’objectif de cette thèse est d’identifier des relations entre phénomènes mécaniques irréversibles (fissuration et délamination) aux grandes déformations et propriétés magnétiques de films minces d’épaisseurs nanométriques (alliages de CoFeB et NiFe) élaborés sur substrat polymère (Kapton®) par pulvérisation magnétron. Dans un premier temps, des essais de traction couplés in situ à la microscopie à forces atomiques ou des mesures de résistance électrique ont permis d’étudier la multifissuration des films minces et les décollements localisés (cloques) subséquents. Ces mesures ont permis de mettre en évidence des domaines de déformations macroscopiques pour lesquels chaque mécanisme était prépondérant. De plus l’énergie d’adhésion a pu être discutée et estimée à partir du suivi des cloques sous déformation. Dans un second temps, des mesures par résonance ferromagnétique effectuées ex situ ont permis de relier les domaines des déformations identifiés précédemment aux évolutions de l’anisotropie magnétique des films minces. De plus, une corrélation entre hétérogénéités de déformations et coefficient d’amortissement de Gilbert a été trouvée. Enfin, les propriétés magnétomécaniques de réseaux de nanolignes de NiFe ont permis de mettre en évidence l’intérêt de la nanostructuration pour ces systèmes magnétiques déformables.
edgalilee_th_2017_merabtine.pdf (119.83 Mo) Télécharger le fichier
tel-02290650 , version 1 (17-09-2019)
  • HAL Id : tel-02290650 , version 1
Skander Merabtine. Etude expérimentale de la multifissuration et de la décohésion de films minces et nanostructures magnétiques sur substrats flexibles : effet sur l'anisotropie magnétique. Mécanique des matériaux [physics.class-ph]. Université Sorbonne Paris Cité, 2017. Français. ⟨NNT : 2017USPCD058⟩. ⟨tel-02290650⟩
240 Consultations
21 Téléchargements
