Étude du devenir des tourbillons des Aiguilles et de leur transport dans l’océan Atlantique Sud à partir d’observations satellitaires et in situ - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2019
Assessments on the fate of the Agulhas Rings and their transport in the South Atlantic estimated by combining satellite altimetry and in situ observations
The Indo-Atlantic interocean heat exchanges are tightly linked to global ocean circulation and climate. They are principally achieved by the Agulhas Rings (AR) which are investigated in this thesis by means of 24 years of daily satellite-altimetry maps and Argo floats profiles.By applying the TOEddies eddy identification and tracking algorithm, developped in this study, to daily maps of Absolute Dynamical Topography (ADT), we estimate Agulhas Rings origins, paths and lifetime. The main novelty lies in the detection of numerous eddy splitting and merging events that leads to the definition of a network of trajectories instead of a biunivocal identification between an eddy with a single trajectory. The results obtained by the network differ considerably with previous estimates connecting eddies formed in the Indian Ocean upstream of the Agulhas Current to eddies in the Brazil Current.The collocation of the reconstructed segments of AR trajectories with Argo profiling floats gives access to their thermohaline structure which allows to estimate their in-route evolution. In particular, we show modification of an AR, transitioning from a surface to a subsurface intensified eddy while it subduct when entering the South Atlantic subtropical gyre. This transformation results in the creation of two Mode Water cores which concentrate most of the heat content of this AR.Finally, an estimate of AR geographical distribution was obtained from the numerous eddies detected in the Cape Basin and South Atlantic Ocean. It shows that AR generally subduct when they leave the Cape Basin. Moreover, for each eddy sufficiently sampled by Argo floats, we were able to estimate its heat content anomaly with respect of the environment. AR heat content anomalies result to be important all along their trajectories even if they release heat along their path. Combining both eulerian and lagrangian methods, we estimate the sub-surface heat transport achieved by their AR while they propagate in the South Atlantic.
Les échanges de chaleur entre les océans Indiens et Atlantiques sont étroitement liés à la circulation globale et au climat. Ceux-ci sont principalement réalisés par les Anneaux des Aiguilles (AR pour "Agulhas Rings'') qui sont étudiés dans cette thèse à l'aide de cartes quotidiennes d'altimétrie satellitaire et de profils hydrologiques de flotteurs Argo.En développant et appliquant l'algorithme d'identification et de suivi des tourbillons TOEddies à 24 années de cartes de la topographie dynamique absolue, nous estimons les origines, les trajectoires et la durée de vie des AR. La principale nouveauté réside dans la détection de nombreux événements de fractionnement et de fusion des tourbillons. Cette innovation conduit à la définition d'un réseau de trajectoires au lieu d'une identification biunivoque entre un tourbillon et une trajectoire. Les résultats ainsi obtenus diffèrent considérablement des évaluations précédentes en connectant des tourbillons formés dans l'océan Indien en amont du courant des Aiguilles à d'autres dans le courant du Brésil.La collocation des segments reconstruits des trajectoires des AR avec les profileurs Argo donne accès à leur structure thermohaline ce qui permet d'en estimer l'évolution au cours de leur propagation. En particulier, nous montrons la modification d'un AR passant d'une structure de surface à une de sub-surface dû à sa subduction lors de son entrée dans le gyre subtropical de l'Atlantique Sud. Cette transformation se traduit par la création de deux cœurs d'eau Modale qui concentrent la majeure partie du contenu de chaleur de cet AR.Enfin, une estimation de la répartition géographique de plusieurs AR est obtenue à partir des tourbillons détectés dans le bassin du Cap et dans l'océan Atlantique Sud. Cette répartition géographique montre que, en général, les AR subductent lorsqu'ils quittent le bassin du Cap. De plus, pour chaque tourbillon suffisamment échantillonné par les flotteurs Argo, nous estimons son anomalie de contenu thermique calculée en fonction de son environnement. Ces anomalies s'avèrent être importantes tout au long de leur trajectoire bien que les AR perdent de la chaleur en se propageant. En combinant des méthodes eulériennes et lagrangiennes, nous estimons le transport de chaleur en sub-surface effectué par les AR lors de leur propagation dans l'Atlantique Sud.
76741_LAXENAIRE_2019_archivage.pdf (209.81 Mo) Télécharger le fichier
tel-02293794 , version 1 (22-09-2019)
tel-02293794 , version 2 (24-09-2019)
  • HAL Id : tel-02293794 , version 2
Rémi Laxenaire. Étude du devenir des tourbillons des Aiguilles et de leur transport dans l’océan Atlantique Sud à partir d’observations satellitaires et in situ. Océan, Atmosphère. Université Paris Saclay (COmUE), 2019. Français. ⟨NNT : 2019SACLX005⟩. ⟨tel-02293794v2⟩
367 Consultations
38 Téléchargements
