Réalisation et optimisation de biocapteurs à base de nanostructures SiC pour la détection électrique d’ADN - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2019
Realization and optimization of biosensors based on SiC nanostructures for the electrical detection of DNA
Sensing of low concentrations of nucleic acids is essential to a variety of applications such as bio-medical analysis, in which case it allows the diagnosis of pathologies by identifying specific biomarkers. Compared to traditional sensing techniques based on biochemistry, the advantage of electrical field-effect detection is that it relies on a direct, label-free, and fast-response measurement. Transistors based on semiconducting nanowires are promising devices that theoretically enable very low detection limits and a high sensitivity, thanks to their high surface-to-volume ratio and unique electronic properties. Silicon carbide (SiC) is a semiconductor material with qualities such as very high physical and chemical stability and high biocompatibility, which make it particularly suited for aforementioned applications.In this thesis, field-effect transistors based on Si and SiC nanowires were designed with a top-down approach to be fabricated using photolithography techniques. The Si-based process was developed and optimized in order to fabricate reproducible devices made of nanowires and nanoribbons. A detailed study was conducted to demonstrate the superior chemical stability of SiC nanowires over Si nanowires under physiological conditions. Based on these results, we investigated two ways of elaborating a thin SiC layer around these Si nanostructures to provide them with its chemical resistance in liquid medium. These reproducible core-shell Si/SiC devices were eventually functionalized and integrated into a microfluidic system in order to achieve novel measurements of DNA detection in real time and in liquid media.
La détection de faibles concentrations d’acides nucléiques est essentielle pour certaines applications comme la biologie médicale, où elle permet le diagnostic d’une multitude de pathologies par l’identification de biomarqueurs spécifiques. Par rapport aux techniques traditionnelles de détection par voie biochimique, la détection électrique par effet de champ présente l’avantage d’être une mesure directe, sans marquage, et à réponse rapide. Les transistors à nanofils semiconducteurs sont des dispositifs prometteurs qui permettent potentiellement d’atteindre des limites de détection très basses et une sensibilité élevée, grâce à leur grand rapport surface/volume et leurs propriétés électroniques uniques. Le carbure de silicium (SiC) est un matériau semiconducteur dont les qualités le rendent particulièrement adapté aux applications visées, telles que sa très grande stabilité physico-chimique et biocompatibilité.Dans cette thèse, des transistors à effet de champ à base de nanofils de Si et SiC ont été conçus dans une approche descendante pour être fabriqués par photolithographie. Un procédé de fabrication basé sur la filière silicium a été développé et optimisé afin de réaliser des dispositifs à nanofils et à nanorubans de Si de manière reproductible. Une étude détaillée a permis de démontrer la stabilité chimique supérieure des nanofils de SiC par rapport aux nanofils de Si en conditions physiologiques. Fort de ce résultat, nous avons exploré deux approches pour l’élaboration d’une couche mince de SiC autour de ces nanostructures de Si, pour leur conférer cette résistance chimique en milieu liquide. Ces dispositifs cœur-coquille Si/SiC reproductibles ont finalement été fonctionnalisés et intégrés dans un système microfluidique complet afin de réaliser des premières mesures novatrices de détection de pH et d’ADN en temps réel et en milieu liquide.
BANGE_2019_archivage.pdf (41.45 Mo) Télécharger le fichier
tel-02318622 , version 1 (17-10-2019)
  • HAL Id : tel-02318622 , version 1
Romain Bange. Réalisation et optimisation de biocapteurs à base de nanostructures SiC pour la détection électrique d’ADN. Micro et nanotechnologies/Microélectronique. Université Grenoble Alpes, 2019. Français. ⟨NNT : 2019GREAT007⟩. ⟨tel-02318622⟩
232 Consultations
16 Téléchargements
