Elaboration de borures et phosphures métalliques : synthèse de nanomatériaux en sels fondus et réactivité de surface - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2017
Elaboration of metal boride and phosphide nanomaterials : synthesis in molten salts and surface reactivity
This PhD work deals with a novel synthesis of metal boride and metal phosphide nanomaterials. Nanostructures of these solids are subject to an increasing interest due to their exciting properties for various applications fields such as superconductivity, high temperature thermoelectricity, energy conversion and storage. In this work, the catalytic and electrocatalytic properties of these nanomaterials are explored. First of all, borides of various transition metals, such as nickel, palladium or a nickel-cobalt composite are studied. To do so, a new liquid-phase synthesis was developed, based on the reactivity of already formed metal nanoparticles with a boron precursor in inorganic molten salts. This new synthesis allowed a precise control over the nanoparticle morphology, size, composition and crystalline structure. By accessing such nanoscale objects, we were able to investigate their properties and performances, especially in the fields of catalysis with the hydrodeoxygenation reaction and electrocatalysis for the hydrogen evolution reaction and oxygen evolution reaction. Finally, the reactivity of red phosphorus in molten salts was addressed, thus paving the way to the extension of this synthetic pathway to metal phosphides.
Ce travail de thèse a pour objet le développement d'une nouvelle voie de synthèse de nanomatériaux métalliques à base d'éléments légers : bore et phosphore. L'intérêt porté à ces composés s'explique par les propriétés variées qu'ils présentent, tels que la supraconductivité, la thermoélectricité ou le stockage d'énergie. Dans le cadre de ce travail, les domaines de la catalyse et de l'électrocatalyse sont explorés. Les borures de différents métaux de transition, en particulier le nickel, le palladium et un composite nickel-cobalt, ont tout d'abord été étudiés. Pour cela une synthèse a été mise au point, reposant sur la réactivité de nanoparticules métalliques avec un précurseur de bore en milieu sels fondus inorganiques. Elle a notamment permis d'obtenir des nanoparticules de borures de nickel avec un bon contrôle de composition, structure, morphologie et taille. Les propriétés de ces nanomatériaux ont par la suite été étudiées en catalyse dans la réaction d'hydrodésoxygénation, et en électrocatalyse dans les réactions de génération d'hydrogène ou d'oxygène à partir de l'eau. Enfin la réactivité du phosphore rouge en milieu sels fondus a été abordée, ouvrant ainsi une nouvelle voie vers l'élaboration de phosphures de métaux de transition.
2017PA066213.pdf (7.06 Mo) Télécharger le fichier
tel-02320971 , version 1 (20-10-2019)
  • HAL Id : tel-02320971 , version 1
Tsou Hsi Camille Chan Chang. Elaboration de borures et phosphures métalliques : synthèse de nanomatériaux en sels fondus et réactivité de surface. Matériaux. Université Pierre et Marie Curie - Paris VI, 2017. Français. ⟨NNT : 2017PA066213⟩. ⟨tel-02320971⟩
378 Consultations
334 Téléchargements
