Caractérisation, destruction et recyclage des déchets amiantés - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2018
Characterization, destruction and recycling of asbestos waste
To answer the ecological and economic problems of the treatment of Materials Containing Asbestos (MCA), a complete process allowing to handle in an optimal way these waste was proposed. For that purpose, three types of waste were analyzed by several complementary techniques of characterization (X-rays diffraction, Scanning Electron Microscopy, infrared and NMR spectroscopy). These analyses allowed the identification of the present various phases within waste. This identification is necessary, because it allows to adapt in the optimal way for the destruction of the waste. The first stage of the process is a treatment in temperature of the MCA in a solution of nitric acid leading to the dissolution of the matrix of the waste and the denaturation of the fibers of chrysotile which are present in 95 % of MCA. Two phases are then got back at the end of this treatment: a solid phase of pure silica and a liquid phase containing, in particular, calcium, magnesium and iron ions. If previous waste contains fibers of amphibole type (5 % of the MCA) they are then treated through a hydrothermal process in an autoclave containing a solution of soda. This stage leads to the complete dissolution of the waste. The basic solution containing some silicon is so got back. Various ways of valuations were then developed. The present ions in the acid solution are chemically sorted out by a selective precipitation of hydroxides. Another way consists in synthesizing a zeolite from the pure silica coming from the acid treatment and from the basic solution after hydrothermal treatment. The isotherms of adsorption of this synthesized zeolite were established to determine its capacity of adsorption of certain polluting metallic cations. To finish, a fundamental study was led on the nanotubes of silica obtained after the acid treatment of pure asbestos fibers and diverse applications of these nanotubes of silica were evoked.
Afin de répondre aux problématiques écologique et économique du traitement des Matériaux Contenant de l’Amiante (MCA), un procédé complet permettant de traiter de manière optimale ces déchets a été proposé. Pour cela, trois types de déchets ont d’abord été analysés par plusieurs techniques de caractérisation complémentaires (diffraction des rayons X, microscopie électronique à balayage, infrarouge et RMN du solide). Ces analyses ont permis l’identification des différentes phases présentes au sein des déchets. Cette identification est nécessaire, car elle permet d’adapter de manière optimale le procédé de destruction au déchet. La première étape de ce procédé est le traitement en température des MCA dans une solution d’acide nitrique. Elle permet la dissolution de la matrice du déchet et la dénaturation des fibres de chrysotile qui sont présentes dans 95 % des déchets amiantés. Deux phases sont alors récupérées à l’issue de ce traitement : une phase solide composée de silice pure et une phase liquide contenant, notamment, du calcium, du magnésium et du fer. Si les déchets contiennent des fibres de type amphibole (5 % des MCA) ils sont ensuite traités par voie hydrothermale dans un autoclave contenant une solution de soude. Cette étape mène à la dissolution complète du déchet. Une solution basique contenant du silicium est ainsi récupérée. Différentes voies de valorisations ont été développées. Les ions présents dans la solution acide sont récupérés par précipitation sélective des hydroxydes. Une autre voie consiste à synthétiser une zéolithe à partir de la silice pure et de la solution basique. Les isothermes d’adsorption de cette dernière ont été tracés afin de déterminer sa capacité d’adsorption de certains cations métalliques polluants. Pour terminer, une étude fondamentale a été menée sur les nanotubes de silice obtenus avec le traitement de fibres d’amiante pures et différentes applications de ces nanotubes de silice ont été évoquées.
TALBI_2018_archivage.pdf (12.47 Mo) Télécharger le fichier
tel-02356560 , version 1 (08-11-2019)
  • HAL Id : tel-02356560 , version 1
Gaël Talbi. Caractérisation, destruction et recyclage des déchets amiantés. Matériaux. Université Montpellier, 2018. Français. ⟨NNT : 2018MONTS135⟩. ⟨tel-02356560⟩
380 Consultations
499 Téléchargements
