Evaluation of new complex medical biological drug based on apoptotic cell efferocytosis proresolutive factors in the treatment of inflammatory bowel diseases
Evaluation des facteurs issus de l'efferocytose comme médicament innovant dans le traitement des maladies inflammatoires chroniques de l'intestin
Inflammation is a natural body defence reaction in response to injuries. The clearance of apoptotic cells by macrophages is at the origin of a pro-resolving microenvironment composed of various soluble factors, allow the arrest of the inflammatory response and to initiate tissue repair. The resolution of inflammation is sometimes defective and contributes to the development of chronic inflammatory diseases, such as chronic inflammatory bowel disease (IBD), which include Crohn's disease (CD) and ulcerative colitis (UC). In this context, we propose to evaluate the therapeutic effect of these pro-resolving factors in the treatment of IBD. This factors derived from the culture of macrophages with apoptotic cells, and called SuperMApo (Supernatant issued from Macrophage Apoptotic cell culture) (Patent # WO2014106666-A1, 2013) contains pro-resolving factors similar to those found in the physiological process of inflammatory resolution, and which may be absent or ineffective in these patients.In this work, we have demonstrated the therapeutic effect of SuperMApo using two experimental models of colitis. To assess the relevance of these models to clinical practice, we have implemented flexible video endoscopy. The therapeutic effect of SuperMApo has been shown to decrease the clinical, endoscopic and histological score of colitis mice, accompanied by improved intestinal permeability and mucosal healing in vivo. This therapeutic effect is related in part to reprogramming of antigen presenting cells (APC), in particular cDC and macrophages, which exhibit less response to TLR ligands, promote induction of Treg and inhibit Th1 production. In addition, SuperMApo induces a marked tissue repair of the intestinal mucosa associated with activation of myofibroblasts, the active form of fibroblasts, and the epithelial intestinal cells (IEC). In particular, SuperMApo increases the migration, proliferation and wound healing properties of these two cell types. This effect depends in part on the growth factors contained in SuperMApo such as TGF-β, IGF-I and VEGF. Finally, preliminary results show that SuperMApo induces a repairing state on fibroblasts from patients with IBD. This opens widely the use of SuperMApo as a clinically approach to propose this new therapeutic option to refractory patients suffering from IBD
La clairance des cellules apoptotiques par les macrophages est à l’origine d’un microenvironnement pro-résolutif composé de différents facteurs solubles, permettant de stopper la réaction inflammatoire et d’engager la réparation tissulaire. La résolution de l’inflammation est parfois défaillante et concourt au développement de pathologies inflammatoires chroniques, comme les maladies inflammatoires chroniques de l’intestin (MICI), qui regroupent la maladie de Crohn (MC) et la rectocolite hémorragique (RCH). Dans ce contexte, nous proposons d’évaluer l’efficacité thérapeutique de l’injection de ces facteurs pro-résolutifs dans le traitement des MICI. Ce produit issu de la culture de macrophages avec des cellules apoptotiques, appelé SuperMApo (Supernatant issued from Macrophage Apoptotic cell culture) (Brevet # WO2014106666-A1, 2013) contient des facteurs pro-résolutifs semblables à ce qu’on retrouve dans le processus physiologique de résolution de l’inflammation, et qui peuvent être absents ou inefficaces chez ces patients.Lors de ce travail, nous avons mise en évidence une efficacité thérapeutique de SuperMApo à l’aide de deux modèles expérimentaux de colite. Pour évaluer la pertinence de ces modèles par rapport à la pratique clinique, nous avons mise en place la vidéo-endoscopie souple. On a montré que l’efficacité de SuperMApo se traduit par diminution du score clinique, endoscopique et histologique des souris colitiques, accompagnée d’une amélioration de la perméabilité intestinale, et de la cicatrisation muqueuse. Cette efficacité thérapeutique est liée en partie à une reprogrammation des cellules présentatrices d’antigènes (APC) notamment de cDC et de macrophages qui présentent moins de réponse aux ligands de TLR, favorisent l’induction de Treg et inhibent la production de Th1. Par ailleurs, SuperMApo induit une cicatrisation nette de la muqueuse intestinale associée à la fois à une activation des myofibroblastes (la forme active des fibroblastes) et des cellules intestinales épithéliales (IEC). Concrètement, SuperMApo augmente les propriétés de migration, de prolifération et de cicatrisation de ces deux types cellulaire. Cet effet dépend en partie des facteurs de croissance au sein de SuperMApo comme le TGF-β, l’IGF-I et le VEGF. Finalement des résultats préliminaires montrent que SuperMApo induit un profil réparateur sur des fibroblastes issus de patients atteints de MICI. L’ensemble de ces résultats montrent, que l’injection de ces facteurs pro-résolutifs permet de mettre en œuvre des mécanismes capables de mettre en place un processus de résolution de l’inflammation et ouvre vers une utilisation clinique de cette approche dans le traitement de MICI.
