Propriétés antifongiques de bactéries lactiques isolées de laits crus - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2012
No
Fermented dairy products such as yogurt, fermented milks and fresh cheeses are of great importance in the French economy. The stability of these products and export opportunities are however limited by frequent fungal spoilages. In addition, the increase of fungal resistances to Chemical preservatives and the strong consumer demand for products deprived of Chemical additives are pushing manufacturers to reduce the quantities of added Chemical preservatives in these products. In this context, it is necessary to develop alternatives to classical food preservation methods, such as biopreservation. Lactic acid bacteria (LAB), used for millennia for diverse food fermentations, and generally recognized as safe for human health, can potentially be used for biopreservation. In order to select 1 or 2 LAB strains with antifungal activity capable to compete in fermented dairy products such as yogurt, a collection of antifungal LAB was first created. This was done by screening colonies isolated from cow, goat and ewe raw milk samples over a one-year period. This screening step, targeted against 4 fungi found in contaminated dairy products, resulted in the isolation of 1235 antifungal colonies. The biodiversity of the isolated antifungal LAB was then determined along with that of the fungi found in the different raw milks, in order to observe a possible correlation between the presence of fungi and the expression of antifungal activities. The influence of milk origin, sampling period, isolation medium and targeted fungus on the percentage of isolated active colonies was highlighted and clearly showed that both cow and goat milks were reservoirs of antifungal LAB. Among the targeted fungi, P. expansum was more easily inhibited, and the majority of colonies were isolated during the third sampling period, mainly on MRS-based media. The majority of identified antifungal LAB belonged to the genus Lactobacillus, mainly to the Lb. casei group. Eleven isolates, including 10 belonging to the Lb. casei group, were selected from these lactobacilli, according to their activity level and action spectrum in MRS medium. Some of their technological properties were characterized for their potential use as protective cultures in fermented dairy products and their antifungal activity was tested in milk and yogurt. To do this, 6 fungal contaminants commonly encountered in yogurt spoilage were used. A particular strain, Lb. harbinensis K.V9.3.1Np, showed a strong antifungal activity in yogurt. Additional experiments showed that the variation of technological parameters (presence or absence of sugar, fermentation time) had no influence on the antifungal activity of this strain. This is the first time that an antifungal potential has been observed for Lb. harbinensis, a species isolated for the first time in 2005 from a fermented vegetable product. Because of its effectiveness in yogurt, Lb. harbinensis K.V9.3.1Np is a promising strain for biopreservation of fermented dairy product(s).
Les produits laitiers fermentés tels que les yaourts, les laits fermentés et les fromages frais, occupent une place importante dans l’économie française. La stabilité de ces produits et leurs chances d’exportation sont cependant limitées par de fréquentes altérations fongiques. De plus, l’augmentation des résistances de certains champignons aux conservateurs chimiques ainsi que la forte demande des consommateurs pour des produits dépourvus d’additifs poussent les industriels à en réduire l’ajout. Dans ce contexte, il est nécessaire de développer des alternatives innovantes, telle que la bio-conservation. Les bactéries lactiques, utilisées depuis des millénaires dans la fermentation de nombreux aliments, et généralement reconnues comme inoffensives pour la santé, sont potentiellement de bonnes candidates pour la bio-conservation. Dans le but d’obtenir une ou deux souches de bactéries lactiques antifongiques, capables d’être compétitives au sein de produits laitiers fermentés tels que le yaourt, une collection de bactéries lactiques antifongiques a d’abord été constituée. Pour cela, un criblage de colonies isolées de laits crus de vache, de chèvre et de brebis a été effectué sur une période d’une année. Ce criblage, ciblé contre 4 champignons communément retrouvés dans les produits laitiers contaminés, a abouti à l’isolement de 1235 colonies de bactéries lactiques antifongiques. Ceci a permis d’évaluer la biodiversité des bactéries lactiques antifongiques d’une part, et celle des champignons, d’autre part, dans ces échantillons de lait, afin d’observer une éventuelle corrélation entre la présence de champignons et l’expression des activités antifongiques. L’influence de l’origine du lait, de la période d’échantillonnage, du milieu d’isolement et du champignon ciblé, sur le pourcentage de colonies actives isolées a été mise en évidence. Parmi les champignons ciblés, Pénicillium expansum était le plus facilement inhibé, et la majorité des colonies ont été isolées durant la troisième période d’échantillonnage, majoritairement sur les milieux à base de MRS. Les laits de vache et de chèvre se sont révélés être des réservoirs de bactéries lactiques antifongiques, contrairement aux laits de brebis. La majorité des bactéries lactiques antifongiques isolées et identifiées appartenait au genre Lactobacillus, majoritairement du groupe Lb. casei. Onze isolats, dont 10 appartenant au groupe Lb. casei, ont été sélectionnés selon l’intensité de leur activité antifongique et leur spectre d’action sur milieu MRS. Certaines de leurs propriétés technologiques ont été caractérisées, en vue de leur utilisation comme cultures protectrices dans des produits laitiers fermentés. Leur activité antifongique a également été testée dans le lait et dans le yaourt, contre 6 contaminants fongiques communément responsables d’altérations dans les yaourts. Une souche, Lb. harbinensis K.V9.3.1Np, a révélé de fortes activités antifongiques dans le yaourt contre 6 cibles fongiques. Les études complémentaires effectuées ont permis de montrer que la variation de certains paramètres technologiques (présence ou absence de saccharose, temps de fermentation) n’avait pas d’influence sur l’activité antifongique de cette souche. La découverte du potentiel antifongique de Lb. harbinensis K.V9.3.1Np est innovante. Cette espèce, isolée pour la première fois en 2005 d’un produit fermenté végétal, n’avait encore jamais été décrite comme présentant des activités antimicrobiennes. Sa forte activité antifongique dans le yaourt fait de Lb. harbinensis K.V9.3.1Np un bon candidat pour la bioconservation de produit(s) laitier(s) fermenté(s).
These-2012-SICMA-Microbiologie-DELAVENNE_Emilie.pdf (9.9 Mo) Télécharger le fichier
tel-02358823 , version 1 (12-11-2019)
  • HAL Id : tel-02358823 , version 1
Emilie Delavenne. Propriétés antifongiques de bactéries lactiques isolées de laits crus. Microbiologie et Parasitologie. Université de Bretagne occidentale - Brest, 2012. Français. ⟨NNT : 2012BRES0085⟩. ⟨tel-02358823⟩
932 Consultations
849 Téléchargements
