Functionalised Imidazoporphyrins and their application in catalysis
Imidazoporphyrines fonctionnalisées et leurs applications en catalyse
A broad series of functionalized imidazo[4,5-b]porphyrins was synthesized by the acid-catalyzed condensation of 2,3-dioxo-5,10,15,20-tetraarylchlorins with aromatic aldehydes. Both steric and electronic features of meso-aryl substituents influence on the product yield ranging from 18% to 90%.Single-crystal X-ray diffraction analysis of the structure of zinc(II) 5,10,15,20-tetramesityl-2-(4-pyridyl)-1H-imidazo[4,5-b]porphyrinate showed that this compound forms 1D coordination chains in the solid state.The post-synthetic modifications of imidazo[4,5-b]porphyrins were investigated by performing the Suzuki-Miyaura coupling reaction, preparing water-soluble imidazoporphyrins and linear/angular bis(imidazo)porphyrins.Several methods of grafting of imidazoporphyrins on the surface of mesoporous TiO2 and ZrO2 were investigated to prepare hybrid materials for catalysis.Then, it was demonstrated that indium(III) 5,10,15,20-tetramesityl-2-(4-diethoxyphospho-rylphenyl)-1H-imidazo[4,5-b]porphyrinate catalyzes the photooxidation of sulfides to sulfoxides by oxygen from air. This complex grafted on TiO2 surface was efficient as a reusable catalyst in spite of partial (1%) leaching of imidazoporphyrin in solution. TiO2-supported manganese(III) 5,10,15,20-tetramesityl-2-(4-diethoxyphosphoryl-phenyl)-1H-imidazo[4,5-b]porphyrinate was employed for catalytic oxidation of a broad range of sulfides by pure oxygen in the presence of isobutyraldehyde. All sulfoxides were obtained in high yields (>89%). The catalyst was reused in 7 consecutive cycles without loss of its efficiency and selectivity. Leaching of the catalyst was not observed under studied conditions.
Une large série d’imidazo[4,5-b]porphyrines a été synthétisée par condensation acido catalysée du 2,3-dioxo-5,10,15,20-tétraarylchlorines avec des aldéhydes aromatiques. Les propriétés stériques et électroniques des substituants méso-aryle sur le macrocycle tétrapyrrolique ont une influence importante sur le rendement en produit qui peut varier de 18% à 90%. L'analyse par diffraction des rayons X de la structure cristalline du 5,10,15,20-tétramésityl-2-(4-pyridyl)-1H-imidazo[4,5-b]porphyrinate de zinc(II) a montré qu'à l'état solide ce complexe forme des polymères de coordination. Ensuite, différentes méthodes de greffage des imidazoporphyrines sur la surface de TiO2 et ZrO2 mésoporeux ont été étudiées pour évaluer l'intérêt de ces matériaux hybrides en catalyse. La photo-oxydation en milieu homogène des sulfures en sulfoxydes par l'oxygène de l'air en présence de 5,10,15,20-tétramésityl-2-(4-diéthoxyphosphorylphényl)-1H-imidazo[4,5-b]porphyrinate d'indium(III) a été mis en œuvre. Il a été ainsi montré que le complexe supporté par le TiO2 pouvait être recyclé plusieurs fois malgré un lessivage partiel (1%) du catalyseur en solution. Puis, le 5,10,15,20-tétramésityl-2-(4-diéthoxyphosphorylphényl)-1H-imidazo[4,5-b]porphyrinate de manganèse(III) supportée par TiO2 a été utilisé comme catalyseur pour l'oxydation de sulfures en sulfoxydes par l'oxygène moléculaire en présence d'isobutyraldéhyde. Une large série de sulfoxydes a été préparée avec des rendements élevés (> 89%). Le catalyseur a été recyclé 7 fois sans perte de son efficacité et de sa sélectivité. Dans les conditions mises en jeu le lessivage du catalyseur en solution n'a pas été observé.
