Localisation d'un robot humanoïde en milieu intérieur non-contraint - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2019
Localization of a humanoid robot in a non-constrained indoor environment
After the democratization of industrial robots, the current trend is the development of social robots that create strong interactions with their users. The deployment of such platforms in shops, museums or train stations raises various issues including the autonomous localization of mobile robots. This thesis focuses on the localization of Pepper robots in a non-constrained indoor environment. Pepper robots are daily used in many shops in Japan and must be as autonomous as possible. However, localization solutions in the literature suffer from the limitations of the platform. This thesis is split into two main themes. First, the problem of relocalization in a visually redundant environment is studied. The proposed solution combines vision and Wi-Fi in a probabilistic approach based on the appearance. Then, the question of a consistent metrical mapping is examined. In order to compensate the numerous losses of tracking caused by the low acquisition frequency, odometric constraints are added to a bundle adjustment optimization. These solutions have been tested and validated on several Pepper robots, from data collected in different indoor environments over more than 7 km.
Après la démocratisation des robots industriels, la tendance actuelle est au développement de robots sociaux dont la fonction principale est l'interaction avec ses utilisateurs. Le déploiement de telles plate-formes dans des boutiques, des musées ou des gares relance différentes problématiques dont celle de la localisation pour les robots mobiles. Cette thèse traite ainsi de la localisation du robot Pepper en milieu intérieur non-contraint. Présent dans de nombreuses boutiques au Japon, Pepper est utilisé par des personnes non-expertes et doit donc être le plus autonome possible. Cependant, les solutions de localisation autonome de la littérature souffrent des limitations de la plate-forme. Les travaux de cette thèse s'articulent autour de deux grands axes. D'abord, le problème de la relocalisation dans un environnement visuellement redondant est étudié. La solution proposée consiste à combiner la vision et le Wi-Fi dans une approche probabiliste basée sur l'apparence. Ensuite, la question de la création d'une carte métrique cohérente est approfondie. Pour compenser les nombreuses pertes de suivi d'amers visuels causées par une fréquence d'acquisition basse, des contraintes odométriques sont ajoutées à une optimisation par ajustement de faisceaux. Ces solutions ont été testées et validées sur plusieurs robots Pepper à partir de données collectées dans différents environnements intérieurs sur plus de 7 km.
2019PSLEM026_archivage.pdf (90.4 Mo) Télécharger le fichier
tel-02368079 , version 1 (18-11-2019)
  • HAL Id : tel-02368079 , version 1
Mathieu Nowakowski. Localisation d'un robot humanoïde en milieu intérieur non-contraint. Robotique [cs.RO]. Université Paris sciences et lettres, 2019. Français. ⟨NNT : 2019PSLEM026⟩. ⟨tel-02368079⟩
902 Consultations
57 Téléchargements
