Establishment and characterization of preclinical models of resistance to immune checkpoint inhibitors
Établissement et caractérisation de modèles précliniques de résistance aux inhibiteurs de points de contrôles immunitaires
Because of the limited efficacy and the toxicity of conventional therapies to fight cancer, researchers focused on the new trategies. These efforts lead to the emergence of immunotherapies, whose msot recent actors are the monoclonal antibodies targeting immune checkpoint (ICP). Among those ICP inhibitors, we found antibodies targeting the surface protein « Programmed Cell Death 1 », called anti- PD1, and those targeting its ligand, « Programmed Cell Death Ligand 1 », called anti- PDL-1. Those antibodies shown a great efficacy in a wide diveristy of cancers, and are currently used for clinical practice in the case of melanoma, lung cancer, bladder cancer and renal cell carcinoma. However, those treatments don’t benefit to all tumor bearing patients, with a mean of 60% of innate resistance, and 25% of acquired resistance following a primary response, variable according to tumor type. Phenomena involved in resistance are currently poorly described. In this context, the aim of my project was to establish in vivo preclinical models of acquired resistance to anti-PD1 and anti-PDL-1. To do that, we used syngeneic renal cancer (RENCA), bladder cancer (MB49 and MBT-2), and colorectal cancer (MC38), and immunocompetent mice, that we have made resistant by serial reimplantations of tumors pieces and serial treatments, inducing a selection pressure until we obtained a resistant phenotype. The efficiency of PD1/PDL-1 axis blocking is strongly linked to the microenvironment composition, as a result we realized an immunophenotyping protocol. We observed anti-tumor cells as T cells, Natural Killer cells, and M1 macrophages, but also cells harboring immunosuppressive functions, as M2 macrophages, MDSC, and Treg. Moreover, some studies have identified an upregulation of alternatives ICP in the context of acquired resistance to anti-PD1, so we also observed the expression of LAG3, TIM3 and TIGIT besides PD1 and PDL-1 expression. We shown that resistance is strongly dependant to the tumor model, even if we identified a decrease of anti-tumor M1 macrophages is models resistant to anti-PD1, and an increase of Treg in models resistant to anti-PDL-1, suggesting a common mechanism of resistance specific to respectively anti PD1 and anti-PDL-1. Following Zaretsky and al. identification of genes involved in interferon pathway in the case of acquired resistance to anti-PD1 in melanoma, we decided to study the molecular profile of resistant tumors. We identified 5 common genes differently modulated between anti-PD1 and anti-PDL-1 resistant models, including SERPINF1 and FCNA which seems to be promising as targets to validate. Lastly, in parallel to establishment and characterization of preclinical models of acquired resistance, we tested new therapeutical approches of anti-PD1 and anti- PDL-1 potentiation in combination with reference chemotherapies. We shown a synergy in wild-type colorectal and bladder cancers (MC38 and MB49), no effect of the combination in metastatic breast cancer 4T1, and an inhibition of anti-PDL 1 effect in bladder cancer MBT-2. Immunphenotyping of tumors allowed us to observe here also high differences between tumor models, both at baseline and after treatments initiation. To conclude, even if our results need a validation with patients samples, we demonstrated that different cellular and molecular modifications could be involved in resistance to anti-PD1 and anti-PDL-1, and that resistance could be bypass with chemotherapy combination, according to tumor type
En raison du manque d'efficacité et de la toxicité des thérapies conventionnelles contre le cancer, la recherche s'est concentrée sur le développement de nouvelles stratégies. Ces efforts ont été à l'origine de l'essor de l'immunothérapie, dont les acteurs les plus récents sont les anticorps monoclonaux ciblant les points de contrôles immunitaires (PCI). Parmi ces inhibiteurs des PCI, on retrouve les anticorps ciblant la protéine de surface « Programmed Cell Death 1 », les anti-PD1, et ceux ciblant son ligand, « Programmed Cell Death Ligand 1 », les anti-PDL-1. Ces anticorps ont démontré une efficacité spectaculaire dans plusieurs types de cancers, et sont aujourd'hui couramment utilisés en clinique comme thérapies dans le mélanome, le cancer du poumon, de la vessie et du rein. Cependant, ces traitements ne profitent pas à tous les patients atteints de cancer, avec en moyenne 60% de résistance innée, et 25% de résistance acquise après une réponse primaire aux anticorps, variable selon le type de tumeur. Les phénomènes impliqués dans la résistance sont à l'heure actuelle peu connus. Ainsi, l'objectif de mon projet de recherche consistait à établir des modèles in vivo de résistance acquise aux anti-PD1 et anti-PDL 1. Pour ce faire, nous avons utilisé des tumeurs syngéniques de rein (RENCA), de vessie (MB49 et MBT-2) et de colon (MC38) et des souris immunocompétentes, que nous avons rendues résistantes aux traitements en les soumettant à des séries de réimplantation de tumeurs et de traitements, induisant une pression de sélection jusqu'à l'obtention d'un phénotype résistant. Le succès du blocage de l'axe PD1/ PDL-1 étant fortement lié à l'état du microenvironnement tumoral, nous avons mis en place un protocole d'immunophénotypage. Nous avons ainsi pu observer les cellules au profil « anti-tumoral », telles que les cellules T, les Natural Killer, et les macrophages M1, mais également les cellules ayant une fonction immunosuppressive, telles que les macrophages M2, les MDSC, les Treg. Enfin, certaines études ayant identifié une sur-régulation des PCI inhibiteurs alternatifs dans les cas de résistance acquise à l'anti-PD1, nous avons également observé l'expression de LAG3, TIM3 et TIGIT en plus de l'expression de PD1 et PDL-1. Nous avons ainsi pu déterminer que la résistance semble très fortement dépendante du modèle tumoral, même si nous avons pu identifier une diminution des macrophages M1 anti-tumoraux dans l'ensemble des modèles résistants à l'anti- PD1, et une augmentation des Treg dans les modèles résistants à l'anti-PDL-1, suggérant un mécanisme commun de résistance propre respectivement à l'anti-PD1 et à l'anti-PDL-1. Suite à l'identification par Zaretsky et al. de gènes impliqués dans la voie interféron dans des cas de résistance acquise de mélanome traité à l'anti- PD1, nous avons également décidé d'étudier le profil moléculaire des tumeurs résistantes. Cela nous a permis d'identifier 5 gènes communs entre les modèles anti- PD1 et anti-PDL-1 résistants, dont SERPINF1 et FCNA qui semblent prometteurs comme cibles à valider. Enfin, en parallèle de l'établissement et de la caractérisation des modèles de résistance acquise, nous avons testé de nouvelles approches thérapeutiques de potentialisation des anticorps anti-PD1 et anti-PDL-1 en combinaison avec des chimiothérapies de référence pour le cancer étudié. Nous avons ainsi démontré une potentialisation dans les modèles sauvages de cancer du côlon MC38 et de la vessie MB49, aucun effet de la combinaison dans le modèle de cancer du sein métastatique 4T1, et une inhibition de l'effet de l'anti-PDL-1 avec la combinaison dans le modèle de vessie MBT-2. L'immunophénotypage nous a permis de constater ici aussi des différences très importantes entre les modèles tumoraux, au niveau basal et après traitement [etc...]
