Abstract : The intricate error sources within different stages of the Additive Manufacturing (AM) process have brought about major issues regarding the dimensional and geometrical accuracy of the manufactured product. Therefore, effective modeling of the geometric deviations is critical for AM. The Skin Model Shapes (SMS) paradigm offers a comprehensive framework aiming at addressing the deviation modeling problem at different stages of product lifecycle, and is thus a promising solution for deviation modeling in AM. In this thesis, considering the layer-wise characteristic of AM, a new SMS framework is proposed which characterizes the deviations in AM with in-plane and out-of-plane perspectives. The modeling of in-plane deviation aims at capturing the variability of the 2D shape of each layer. A shape transformation perspective is proposed which maps the variational effects of deviation sources into affine transformations of the nominal shape. With this assumption, a parametric deviation model is established based on the Polar Coordinate System which manages to capture deviation patterns regardless of the shape complexity. This model is further enhanced with a statistical learning capability to simultaneously learn from deviation data of multiple shapes and improve the performance on all shapes.Out-of-plane deviation is defined as the deformation of layer in the build direction. A layer-level investigation of out-of-plane deviation is conducted with a data-driven method. Based on the deviation data collected from a number of Finite Element simulations, two modal analysis methods, Discrete Cosine Transform (DCT) and Statistical Shape Analysis (SSA), are adopted to identify the most significant deviation modes in the layer-wise data. The effect of part and process parameters on the identified modes is further characterized with a Gaussian Process (GP) model. The discussed methods are finally used to obtain high-fidelity SMSs of AM products by deforming the nominal layer contours with predicted deviations and rebuilding the complete non-ideal surface model from the deformed contours. A toolbox is developed in the MATLAB environment to demonstrate the effectiveness of the proposed methods.
Résumé : Les différentes étapes et processus de la fabrication additive (FA) induisent des erreurs de sources multiples et complexes qui soulèvent des problèmes majeurs au niveau de la qualité géométrique du produit fabriqué. Par conséquent, une modélisation effective des écarts géométriques est essentielle pour la FA. Le paradigme Skin Model Shapes (SMS) offre un cadre intégral pour la modélisation des écarts géométriques des produits manufacturés et constitue ainsi une solution efficace pour la modélisation des écarts géométriques en FA.Dans cette thèse, compte tenu de la spécificité de fabrication par couche en FA, un nouveau cadre de modélisation à base de SMS est proposé pour caractériser les écarts géométriques en FA en combinant une approche dans le plan et une approche hors plan. La modélisation des écarts dans le plan vise à capturer la variabilité de la forme 2D de chaque couche. Une méthode de transformation des formes est proposée et qui consiste à représenter les effets de variations sous la forme de transformations affines appliquées à la forme nominale. Un modèle paramétrique des écarts est alors établi dans un système de coordonnées polaires, quelle que soit la complexité de la forme. Ce modèle est par la suite enrichi par un apprentissage statistique permettant la collecte simultanée de données des écarts de formes multiples et l'amélioration des performances de la méthode.La modélisation des écarts hors plan est réalisée par la déformation de la couche dans la direction de fabrication. La modélisation des écarts hors plan est effectuée à l'aide d'une méthode orientée données. Sur la base des données des écarts obtenues à partir de simulations par éléments finis, deux méthodes d'analyse modale: la transformée en cosinus discrète (DCT) et l'analyse statistique des formes (SSA) sont exploitées. De plus, les effets des paramètres des pièces et des procédés sur les modes identifiés sont caractérisés par le biais d'un modèle à base de processus Gaussien.Les méthodes présentées sont finalement utilisées pour obtenir des SMSs haute-fidélité pour la fabrication additive en déformant les contours de la couche nominale avec les écarts prédits et en reconstruisant le modèle de surface non idéale complet à partir de ces contours déformés. Une toolbox est développée dans l'environnement MATLAB pour démontrer l'efficacité des méthodes proposées.
