Hypothesis of a Non-SNARE-Function of Syntaxin-5 - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2017
Hypothèse d'une fonction non-SNARE de la syntaxine-5
The introduction of my PhD manuscript starts with describing plant and bacterial toxins (chapter 9.1), in particular Shiga toxin and Shiga-like toxins (SLTs) (chapter 9.1.2). Small molecule inhibitors of these toxins are summarized afterwards in chapter 9.1.3, notably the Retro-2 compound. Since these toxins rely on intracellular trafficking to reach their molecular targets, a general overview of endocytosis and endosomal trafficking is provided (chapter 9.2). Next, the retrograde route entry is presented (chapter 9.2.5), with focus on clathrin, the retromer and GPP130, a protein that constantly cycles between Golgi, plasma membrane, and endosomes. SNARE proteins, particularly syntaxin-5 and syntaxin-16, are then introduced (chapter 9.2.6). After a brief section of the micro RNA family 199 (chapter 9.3), the introduction finishes with the description of some salient techniques that were used in my work, such as - bio-orthogonal Click-Chemistry, anterograde trafficking synchronization with the retention using selective hooks (RUSH) assay, and the antibody-based proximity ligation assay (chapter 10.6.1, 0, 10.11.1).Herein, my submitted publication opens the results part (chapter 11.1), in which I present the utility of biorthogonal click chemistry for the search of the cellular targets of Retro-2, a small molecule inhibitor that was previously shown to protect cells and animals against Shiga toxin and ricin. I describe that Sec16A is a likely cellular target candidate, and illustrate using the RUSH approach how interfering with Sec16A functions leads to the partial relocalization of syntaxin-5 to the endoplasmic reticulum (ER) by slowing-down its anterograde transport. The second part of the paper describes how syntaxin-5 relocalization causes the inhibition of Shiga toxin trafficking from endosomes to the TGN. I present a novel interaction between syntaxin-5 and the Golgi protein GPP130, which both have been already described in relation to Shiga toxin trafficking. My work connects both trafficking factors in retrograde trafficking at the endosomes-TGN interface. Strikingly, I demonstrate that this interaction is most probably based on a non-SNARE function of syntaxin-5.In collaboration with Juan Francisco Aranda and Carlos Fernandez in the US, we put micro RNAs into an endogenous regulation context of Shiga toxin retrograde trafficking (chapter 11.2). An extended discussion will be given in chapter 12.Last, a general outlook of ongoing projects is given in the perspectives section (chapter 13), in which further collaborations are highlighted.Keywords: Retrograde transport, Shiga toxin, Shiga-like toxin (SLT), STxB, syntaxin-5, Sec16A, GPP130, Retro-2, Retro-2.1, azide-functionalized Retro-2, copper-free click chemistry, small molecule target identification, mass spectrometry, non-SNARE function, anterograde trafficking inhibition, miRNA, miR199, retromer, VPS26
L’introduction commence avec la description de toxines d’origines bactérienne et végétale, en particulier la toxine Shiga ainsi que les toxines de la même famille (chapitre 9.1.2). Les petites molécules inhibitrices de ces toxines sont ensuite résumées dans le chapitre 9.1.3, en particulier le composé Retro-2. L’efficacité de ces toxines à atteindre leurs cibles reposant sur le trafic intracellulaire, un aperçu général de l’endocytose et du trafic endosomal sont présentés (chapitre 9.2). Puis, l’entrée de la voie rétrograde est décrite (chapitre 9.2.5), avec un intérêt particulier porté sur la clathrine, le rétromère et GPP130, une protéine qui circule de manière continue entre le Golgi, la membrane plasmique et les endosomes. Les protéines SNARE, en particulier la syntaxine-5 et le syntaxine-16, sont ensuite introduites (chapitre 9.2.6). Après une brève section sur les micro-ARNs de la famille 199 (chapitre 9.3), l’introduction se termine avec la description des techniques clés utilisées au cours de mon travail, tels que la chimie click bio-orthogonale, la synchronisation du trafic antérograde par rétention grâce à des hameçons spécifiques (RUSH), et la ligation par proximité basé sur des anticorps (chapitre 9.4).Ci-inclus, mon article en cours de soumission ouvre la partie résultats (chapitre 10.1), dans laquelle je présente l’intérêt de la chimie click bio-orthogonale pour identifier les cibles cellulaires de Retro-2. Je décris un des candidats potentiels, Sec16A, et illustre comment grâce à la technique de RUSH, perturber la fonction de Sec16A conduit à la relocalisation partielle de la syntaxin-5 au niveau du reticulum endoplasmique via l’inhibition du transport antérograde de la syntaxine-5. La seconde partie de l’article décrit comment la relocalisation de la syntaxine-5 induit l’inhibition du trafic de la toxine Shiga des endosomes au TGN. Je présente une nouvelle interaction entre la syntaxine-5 et la protéine TGN GPP130, qui ont déjà été caractérisées en relation avec le trafic de la toxine Shiga. Mon travail connecte à la fois les facteurs de trafic avec le trafic rétrograde au niveau de l’interface endosome-TGN. De manière frappante, cette interaction est très probablement basée sur une fonction non-SNARE de la syntaxine-5 car le domaine de fixation sur GPP130 est structurellement non lié à toute fonction SNARE.En collaboration avec Juan Francisco Aranda et Carlos Fernandez aux Etats-Unis, nous avons placés des micro-ARNs dans un contexte de régulation endogène du trafic rétrograde de la toxine Shiga (chapitre 11.2). Une discussion plus approfondie sera apportée dans le chapitre 12.Enfin, une vue d’ensemble des projets en cours est apportée dans la section des perspectives (chapitre 12), dans laquelle les collaborations plus approfondies sont mises en lumière.Mots clés : transport rétrograde, toxine Shiga, toxine de la famille Shiga, STxB, syntaxin-5, Sec16A, GPP130, Retro-2, Retro-2.1, chimie click sans cuivre, identification des cibles de petites molécules, spétrométrie de masse, function non-SNARE, inhibition du trafic antérograde, miARN, miR199, rétromère, VPS26
76656_RATHJEN_2017_archivage.pdf (10.78 Mo) Télécharger le fichier
tel-02408332 , version 1 (13-12-2019)
  • HAL Id : tel-02408332 , version 1
Stefan Rathjen. Hypothesis of a Non-SNARE-Function of Syntaxin-5. Molecular biology. Université Paris Saclay (COmUE), 2017. English. ⟨NNT : 2017SACLS450⟩. ⟨tel-02408332⟩
179 Consultations
204 Téléchargements
