Étude de la perfusion cérébrale par Arterial Spin Labeling en IRM à 1.5T chez le nouveau-né et l’enfant - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2018
Brain perfusion imaging using Arterial Spin labeling 1.5T MRI scan in neonates and children
Physiological changes in overall and regional cerebral perfusion are related to age and neurocognitive development. Brain perfusion in the pediatric population can be assessed using a number of imaging techniques. Two literature reviews were undertaken and published on this topic: one based on brain perfusion imaging techniques in neonates, and the other based on the ASL technique in the pediatric population and its clinical applications. The Arterial Spin Labeling (ASL) MRI perfusion sequence is one of the most suitable imaging techniques for children given that the procedure is non-irradiating and non-invasive (without exogenous contrast agent injection). There are many emerging cerebral perfusion imaging applications for children due to the highly convenient implementation of the ASL sequence, which can be easily incorporated into standard brain MRI protocols following acquisition of morphological images. Certain technical adjustments to the imaging parameters are required to account for the fundamental differences between the pediatric and adult populations. Measuring cerebral blood flow (CBF) in neonates and children using ASL therefore requires a number of adaptations to acquisition and related parameters.The processing of ASL data also requires specific adaptations, in particular regarding the automated segmentation of brain tissues, and the parameters used for CBF quantification models. The processing pipeline for both anatomical and perfusion images that had been previously developed by our team for adult data was adapted firstly for children and secondly for neonates. These two populations notably have specific age-related concerns; in particular the signal-to-noise ratio of ASL is very good in children, but much less so in neonates, and the morphological images have inverted contrast due to incomplete myelination at birth. Following adaptation of the processing pipeline, several studies were completed (2 original articles published and 1 under review), showing the clinical benefits of studying cerebral perfusion in three situations: first physiological changes in cerebral perfusion in children between 6 months and 15 years; secondly changes in cerebral perfusion in children with a first attack of migraine with aura; and lastly changes in brain perfusion between day of life 3 and day of life 10 in asphyxiated neonates. Following adaptation of the processing pipeline, several studies were completed (2 original articles published and 1 under review), showing the clinical benefits of studying cerebral perfusion in three situations: first physiological changes in cerebral perfusion in children between 6 months and 15 years; secondly changes in cerebral perfusion in children with a first attack of migraine with aura; and lastly changes in brain perfusion between day of life 3 and day of life 10 in asphyxiated neonates. Several studies are still in progress, and these present new image processing challenges, involving, for example, children with neurosurgical conditions and morphological changes in the brain, or premature babies, in line with the work undertaken for this thesis.
L’imagerie IRM de perfusion par Arterial Spin Labeling (ASL) ou marquage des spin artériels a pour principal avantage d’être une méthode d’imagerie non invasive (non irradiante et sans injection de produit de contraste exogène), particulièrement adaptée à l'imagerie cérébrale pédiatrique. Sa facilité de mise en œuvre explique l’engouement pour cette séquence et de nombreuses applications cliniques émergentes. Cette technique initialement développée chez l’adulte nécessite une adaptation à la population pédiatrique, aussi bien des paramètres d’acquisition et de quantification que des algorithmes de traitement d’images. La perfusion cérébrale globale et régionale évolue physiologiquement, parallèlement à l’âge et au développement neurocognitif. Il existe plusieurs méthodes d’étude de la perfusion cérébrale pédiatrique. Dans ce contexte, deux revues de littérature ont été réalisées et publiées : l’une portant sur les différentes techniques d’imagerie de la perfusion cérébrale chez les nouveau-nés, l’autre se focalisant sur la technique d’ASL en pédiatrie et ses applications cliniques. Puis la chaîne de traitement des images morphologiques et de perfusion ASL, développée chez l’adulte au sein de notre unité, a été adaptée aux enfants puis aux nouveau-nés. Ces deux populations ont effectivement des problématiques différentes, en particulier le rapport signal sur bruit de l’ASL est très bon chez les enfants, mais nettement moins bon chez les nouveau-nés, et les images morphologiques ont un contraste différent en raison d’une myélinisation incomplète à la naissance. Grace à l’adaptation de la chaîne de traitement, des travaux de recherche clinique ont pu être finalisés (2 publiés, 1 soumis) illustrant l’intérêt de l’étude de la perfusion cérébrale dans 3 situations : l’étude de l’évolution de la perfusion cérébrale normale chez l’enfant entre 6 mois et 15 ans ; l’étude de la perfusion cérébrale chez les enfants souffrant d’une première crise de migraine avec aura ; et enfin l’étude de l’évolution de la perfusion cérébrale entre le 3ieme et le 10ieme jour de vie chez les enfants souffrant d’asphyxie périnatale et traités par hypothermie. Plusieurs projets restent en cours sur le sujet, avec d’autres challenges de traitement et d’analyse d’image (enfants de neurochirurgie avec modifications morphologiques du cerveau, ou enfants prématurés par exemple), dans la continuité ce qui a été fait au cours de cette thèse.
PROISY_Maia.pdf (8.69 Mo) Télécharger le fichier
tel-02408336 , version 1 (13-12-2019)
tel-02408336 , version 2 (21-01-2020)
  • HAL Id : tel-02408336 , version 1
Maïa Proisy. Étude de la perfusion cérébrale par Arterial Spin Labeling en IRM à 1.5T chez le nouveau-né et l’enfant. Médecine humaine et pathologie. Université Rennes 1, 2018. Français. ⟨NNT : 2018REN1B052⟩. ⟨tel-02408336v1⟩
356 Consultations
607 Téléchargements
