Kinetic data structures for the geometric modeling of urban environments - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2019
Structures de données cinétiques pour la modélisation géométrique d’environnements urbains
The geometric modeling of urban objects from physical measurements, and their representation in an accurate, compact and efficient way, is an enduring problem in computer vision and computer graphics. In the literature, the geometric data structures at the interface between physical measurements and output models typically suffer from scalability issues, and fail to partition 2D and 3D bounding domains of complex scenes. In this thesis, we propose a new family of geometric data structures that rely on kinetic frameworks. More precisely, we compute partitions of bounding domains by detecting geometric shapes such as line-segments and planes, and extending these shapes until they collide with each other. This process results in light partitions, containing a low number of polygonal cells. We propose two geometric modeling pipelines, one for the vectorization of regions of interest in images, another for the reconstruction of concise polygonal meshes from point clouds. Both approaches exploit kinetic data structures to decompose efficiently either a 2D image domain or a 3D bounding domain into cells. Then, we extract objects from the partitions by optimizing a binary labelling of cells. Conducted on a wide range of data in terms of contents, complexity, sizes and acquisition characteristics, our experiments demonstrate the scalability and the versatility of our methods. We show the applicative potential of our method by applying our kinetic formulation to the problem of urban modeling from remote sensing data.
La modélisation géométrique d'objets urbains à partir de mesures physiques et leur représentation de manière efficace, compacte et précise est un problème difficile en vision par ordinateur et en infographie. Dans la littérature scientifique, les structures de données géométriques à l'interface entre les mesures physiques en entrée et les modèles produits en sortie passent rarement à l'échelle et ne permettent pas de partitionner des domaines fermés 2D et 3D représentant des scènes complexes. Dans cette thèse, on étudie une nouvelle famille de structures de données géométrique qui repose sur une formulation cinétique. Plus précisément, on réalise une partition de domaines fermés en détectant et en propageant au cours du temps des formes géométriques telles que des segments de droites ou des plans, jusqu'à collision et création de cellules polygonales. On propose en particulier deux méthodes de modélisation géométrique, une pour la vectorisation de régions d'intérêt dans des images, et une autre pour la reconstruction d'objets en maillages polygonaux concis à partir de nuages de points 3D. Les deux approches exploitent les structures de données cinétiques pour décomposer efficacement en cellules soit un domaine image en 2D, soit un domaine fermé en 3D. Les objets sont ensuite extraits de la partition à l’aide d’une procédure d’étiquetage binaire des cellules. Les expériences menées sur une grande variété de données en termes de nature, contenus, complexité, taille et caractéristiques d'acquisition démontrent la polyvalence de ces deux méthodes. On montre en particulier leur potentiel applicatif sur le problème de modélisation urbaine à grande échelle à partir de données aériennes et satellitaires.
2019AZUR4091.pdf (109.48 Mo) Télécharger le fichier
tel-02432386 , version 1 (08-01-2020)
tel-02432386 , version 2 (17-06-2020)
  • HAL Id : tel-02432386 , version 2
Jean-Philippe Bauchet. Kinetic data structures for the geometric modeling of urban environments. Discrete Mathematics [cs.DM]. COMUE Université Côte d'Azur (2015 - 2019), 2019. English. ⟨NNT : 2019AZUR4091⟩. ⟨tel-02432386v2⟩
600 Consultations
74 Téléchargements
