New Network / IT Command: Virtualized Function Performance for a Programmable Infrastructure - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2018
Nouvelle commande réseau / IT : Performance des fonctions virtualisées pour une infrastructure programmable
In the framework of Network Function Virtualization (NFV), we address in this work the performance analysis of virtualized network functions (VNFs), wherein the virtualization of the radio access network (namely, Cloud-RAN) is the driving use-case. The overarching principle of network virtualization consists of replacing network functions, which were so far running on dedicated and proprietary hardware, with open software applications running on shared general purpose servers. The complexity of virtualization is in the softwarization of low-layer network functions (namely, PHY functions) because their execution must meet strict latency requirements. Throughout this work, we evaluate the performance of VNFs in terms of latency which consid- ers the total amount of time that is required to process VNFs in cloud computing systems. We notably investigate the relevance of resource pooling and statistical multiplexing when available cores in a data center are shared by all active VNFs. We perform VNF modeling by means of stochastic service systems. Proposed queuing models reveal the behavior of high performance computing architectures based on parallel processing and enable dimensioning the required com- puting capacity in data centers.
Dans le cadre de la virtualisation des fonctions réseau (NFV), nous abordons dans ce travail la analyse des performances des fonctions réseau virtualisées (VNF), dans laquelle la virtualisation du réseau d'accès radio (à savoir, Cloud-RAN) est le cas d'utilisation de conduite. Le principe fondamental de la virtualisation des réseaux consiste à remplacer les fonctions réseau, qui sur du matériel dédié et propriétaire, avec des applications logicielles ouvertes exécutées sur des applications partagées serveurs à usage général. La complexité de la virtualisation réside dans la simplification de la couche inférieure fonctions réseau (à savoir les fonctions PHY) car leur exécution doit respecter une latence stricte exigences. Tout au long de ce travail, nous évaluons les performances des VNF en termes de latence indique le temps total requis pour traiter les VNF dans les systèmes de cloud computing. nous étudier notamment la pertinence de la mise en commun des ressources et du multiplexage statistique lorsqu'ils sont disponibles Les cœurs d'un centre de données sont partagés par tous les VNF actifs. Nous effectuons la modélisation VNF au moyen de systèmes de service stochastiques. Les modèles de file d'attente proposés révèlent le comportement de haute performance des architectures informatiques basées sur le traitement parallèle et permettant de dimensionner les com- mise en capacité dans les centres de données.
these_archivage_3570690.pdf (6.59 Mo) Télécharger le fichier
tel-02612498 , version 1 (01-10-2018)
tel-02612498 , version 2 (19-05-2020)
  • HAL Id : tel-02612498 , version 1
Veronica Karina Quintuna Rodriguez. New Network / IT Command: Virtualized Function Performance for a Programmable Infrastructure. Networking and Internet Architecture [cs.NI]. Sorbonne Université, 2018. English. ⟨NNT : ⟩. ⟨tel-02612498v1⟩
431 Consultations
858 Téléchargements
