Temporal and spatial control of fungal filamentous growth in Candida albicans
Contrôle spatio-temporel de la croissance filamenteuse chez Candida albicans
Candida albicans is a fungal human pathogen that can cause life-threatening infections in immunocompromised patients, in part, due to its ability to switch between an oval budding form and a filamentous hyphal form. The small-Rho GTPase Cdc42 is crucial for filamentous growth and, in its active form, localizes as a tight cluster at the tips of growing hyphae. I have used a light-activated membrane recruitment system comprised of the Arabidopsis thaliana Cry2PHR-CibN domains to control the recruitment of constitutively active Cdc42 to the plasma membrane. I have determined how photorecruitment of constitutively active Cdc42 perturbs filamentous growth and where, when and how new filamentous growth is subsequently initiated. My results demonstrate that, upon photorecruitment of constitutively active Cdc42, filament extension is abrogated and a new growth site can be established in the cell. Location of a new filamentous growth site correlates with the length of the initial filament. I have investigated the molecular mechanisms that underlie the disassembly of an initial growth site and the specific location of the new filamentous growth site. In growing hyphae a cluster of vesicles, referred to as a Spitzenkörper, is localized at the tip of the filament. Upon photorecruitment of constitutively active Cdc42, a new cluster of vesicles, with a composition similar to that of the initial Spitzenkörper, appears in the mother cell. I have followed the dynamics of the Spitzenkörper, active Cdc42, sites of endocytosis, secretory vesicles and actin cables subsequent to disruption of the initial growth site in the filament. Taken together, my results suggest that there is competition for growth between the Spitzenkörper and the cluster of vesicles that forms immediately after the photorecruitment of constitutively active Cdc42 and that a dynamic polarity axis can be established in the absence of directional growth.
Candida albicans est un pathogène fongique opportuniste de l’Homme, qui peut causer des infections superficielles mais aussi systémiques chez les patients immunodéprimés. Sa virulence est associée à sa capacité de changer d’une forme bourgeonnante à une forme hyphale. La petite GTPase de type Rho, Cdc42, est critique pour la croissance filamenteuse et, sous forme activée, sa localisation est restreinte à l’extrémité des hyphes. J’ai utilisé un système photoactivable, constitué des domaines d’Arabidopsis thaliana Cry2PHR-CibN, pour contrôler le recrutement de Cdc42 constitutivement actif à la membrane plasmique. J'ai déterminé comment le photo-recrutement de Cdc42 constitutivement actif perturbe la croissance filamenteuse et où, quand et comment une nouvelle croissance filamenteuse est ré-initiée. Mes résultats démontrent que, lors du photo-recrutement de Cdc42 constitutivement actif, l'extension du filament cesse puis un nouveau site de croissance s’établit dans la cellule. La localisation de ce nouveau site de croissance est corrélée à la longueur du filament. J'ai étudié les mécanismes moléculaires qui sous-tendent le désassemblage du site de croissance initial et l'emplacement spécifique du nouveau site de croissance filamenteuse. Dans les hyphes en croissance, un «cluster» de vésicules, appelé Spitzenkörper, est localisé à l'extrémité du filament. Lors du photo-recrutement de Cdc42 constitutivement actif, un nouveau «cluster» de vésicules, de composition similaire à celui du Spitzenkörper initial, apparaît dans la cellule mère. J'ai suivi la dynamique du Spitzenkörper et la localisation de Cdc42 sous forme activée, des sites d'endocytose, des vésicules de sécrétion et des câbles d’actine suite à la perturbation du site de croissance initial dans le filament. Dans l’ensemble, mes résultats indiquent qu'il existe une compétition pour la croissance entre le Spitzenkörper et le «cluster» de vésicules qui se forme immédiatement après le photo-recrutement de Cdc42 constitutivement actif et qu'un axe de polarité dynamique peut être établi en l'absence de croissance directionnelle.
