Des interactions indirectes entre les proies - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2013
This thesis deals with multi-prey–predators modeling. It is particularly focused on the influence of the behavior of a predator on indirect interactions between its prey, i.e, the effect of the addition of a prey on the other prey. Classical theory predicts the occurrence of negative indirect effects between prey, or apparent competition, resulting from the interaction with a common predator. More recent results identify mechanisms that mitigate these negative effects. Our work revisits the assumptions about these mechanisms in systems composed of two prey and their common predator. After setting the ecological framework by recalling the main types of direct and indirect interactions, we introduce classical predator-prey models. The work then focuses on a family of models with predator negative density dependence coupled with different models of predator behavior when faced with different types of prey. We show that the interactions between these mechanisms can reverse apparent competition and counter-intuitively, increase prey density through their common predator. Our results are relevant to biological control programs, where a common practice aims at fostering biological control agents by providing them with alternative food or shelters. Our theory suggests that such practices may be counter-productive, pest control being disrupted by a predator distraction effect.
Cette thèse a pour objet la modélisation de systèmes multi-proies–prédateurs. Elle s’intéresse particulièrement à l’influence du comportement d’un prédateur sur les interactions indirectes entre ses proies, i.e. l’effet de l’ajout d’une proie sur la densité des autres. La théorie classique prédit l’occurrence d’effets indirects négatifs entre les proies, ou compétition apparente, résultant de l’interaction avec un prédateur commun ; des résultats plus récents identifient certains mécanismes à même d’atténuer ces effets négatifs. Nos travaux revisitent les hypothèses autour de ces mécanismes dans des systèmes composés de deux proies et de leur prédateur commun. Après avoir fixé le cadre écologique en rappelant les principaux types d’interactions directes et indirectes, nous introduisons les modèles proies-prédateurs classiques. Les travaux se concentrent ensuite sur une famille de modèles présentant de la densité-dépendance négative chez les prédateurs couplée à différentes modélisations du comportement des prédateurs lorsqu’ils sont confrontés à plusieurs types de proies. Nous montrons notamment que les interactions entre ces mécanismes peuvent inverser la compétition apparente et, contre-intuitivement, accroître la densité des proies par l’intermédiaire d’un prédateur commun. Nos résultats trouvent pour partie application en lutte biologique, où il est courant de chercher à favoriser les auxiliaires en aménageant leur environnement (apport de nourriture alternative, refuge, ...). Ils suggèrent que de telles pratiques peuvent se révéler contre-productives, le contrôle des ravageurs pouvant être affaibli du fait d’une distraction de leurs prédateurs.
Mots clés
teixeira_manuscrit_1.pdf (28.37 Mo) Télécharger le fichier
tel-02808828 , version 1 (06-06-2020)
  • HAL Id : tel-02808828 , version 1
  • PRODINRA : 179447
Mickaël Teixeira Alves. Des interactions indirectes entre les proies : Modélisation et influence du comportement du prédateur commun. Sciences agricoles. Université Nice Sophia Antipolis, 2013. Français. ⟨NNT : ⟩. ⟨tel-02808828⟩
33 Consultations
4 Téléchargements
