Évaluation et essai d’optimisation de l’activité antifongique des extraits de Termanalia superba sur la croissance in vitro de Aspergillus fumigatus, Candida albicans et Cryptococcus neoformans - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2014
Evaluation and optimization trial of the antifungal activity of Termanalia superba extracts on the in vitro growth of Aspergillus fumigatus, Candida albicans and Cryptococcus neoformans
Marcel Gnamien Ahon
  • Fonction : Auteur
  • PersonId : 1074113
In sub-Saharan Africa, the bark of Terminalia superba (Combretaceaes), commonly called "fraké" are used in the treatment of many skin diseases. To justify such of traditional use the present study was undertaken with the aim to characterize the active principle of this plant. Aqueous (XAq) and ethanol (X0) extracts of bark of Terminalia superba were tested on "in vitro" growth of three fungal organisms as Candida albicans, Cryptococcus neoformans and Aspergillus fumigatus. The ethanol extract (X0) was more effective on the growth of the fungal germs. From X0 the fraction X1.2 gave the best antifungals activities. This last fraction undergoes a finesplit to give G1, G2 and G3. The most active fraction (G3) completely inhibits the growth of Candida albicans and Aspergillus fumigatus with a value of minimum fungicidal concentration (MFC) of 12, 18 mcg / mL, and Cryptococcus neoformans, with a value of CMF 6.09 mcg / mL. The chromatographic and spectrometric analysis (GC / MS and NMR) revealed the presence of two derivatives of ellagic acid in G3. These results support the traditional use of this plant against skin diseases.
En Afrique subsaharienne, les écorces de Terminalia superba (Combretaceaes), communément appelé ״fraké ״, sont utilisées dans le traitement de nombreuses affections cutanées. Afin de justifier cette utilisation traditionnelle, la présente étude a été entreprise avec pour objectif de caractériser le principe actif de cette plante. Des extraits totaux aqueux (XAq) et éthanolique (X0) des écorces de Terminalia superba ont été testés sur la croissance ״in vitro ״ de trois germes fongiques que sont Candida albicans, Cryptococcus neoformans et Aspergillus fumigatus. L’extrait éthanolique (X0) s’est avéré plus efficace sur la croissance des germes fongiques. De la partition de X0 la fraction X1.2 a donné les meilleurs paramètres antifongiques. Cette dernière fraction a subit à son tour un fractionnement plus fin pour donner G1, G2 et G3. La fraction G3 la plus active d’entre elle inhibe totalement la croissance de Candida albicans, de Aspergillus fumigatus avec une valeur de concentration minimale fongicide (CMF) de 12,18μg/mL, et de Cryptococcus neoformans, avec une valeur de CMF de 6,09μg/mL. L’analyse chromatographique et spectrométrique (GC/MS et RMN) a révélé la présence de deux dérivés d’acide éllagique dans l’extrait G3. Ces résultats justifient l’utilisation traditionnelle de cette plante contre les affections cutanées.
Thèse M. AHON Marcel.pdf (3.53 Mo) Télécharger le fichier
tel-02885084 , version 1 (30-06-2020)
  • HAL Id : tel-02885084 , version 1
Marcel Gnamien Ahon. Évaluation et essai d’optimisation de l’activité antifongique des extraits de Termanalia superba sur la croissance in vitro de Aspergillus fumigatus, Candida albicans et Cryptococcus neoformans. Mycologie. Université Félix Houphouêt-Boigny Abidjan (Côte d'Ivoire), 2014. Français. ⟨NNT : ⟩. ⟨tel-02885084⟩
172 Consultations
157 Téléchargements
