X-Ray diagnostics on corium-sodium interactions during a severe accident scenario
Radioscopie X pour les interactions corium-sodium lors d'un scénario d'accident grave
In Sodium-cooled Fast Reactors (SFR), hypothetical failure of the core cooling system or the plant protection system may lead to a severe accident scenario. In such a scenario, core materials (fuel and cladding) melt down generating a hot molten mixture called corium. This corium may interact with the coolant (liquid sodium) leading to Fuel Coolant Interaction (FCI) which can generate energetic events and hence jeopardize the reactor structures. The yield of these energetic events strongly depends on the state of the corium-sodium mixture prior to the energetic event. Therefore, the knowledge of the features of the mixture composed of three-phases (i.e., corium, liquid sodium, and sodium vapor) is crucial. The lack of knowledge on the phenomenology of the interaction emphasizes the need to study it with the help of experiments. PLINIUS-2, the future large-mass experimental platform of CEA Cadarache, will be dedicated to experiments aiming at understanding the interaction phenomenology of prototypic corium with coolant (sodium and water). The present research aims to develop a high-energy X-Ray imaging system for this facility, to visualize and better understand the corium-sodium interaction. An image-processing algorithm to analyze the three-phase repartition is also developed to contribute to the improvement of numerical modeling. This Ph.D. research has been executed in three steps. In the first step, a bibliographic study of the past experiments was carried out to better understand the physics of the interaction and the mechanism of fragmentation during corium-sodium interaction. This bibliographic study, along with a statistical analysis of the particle size distribution data of various experiments conducted in the past, revealed that the particles formed in these tests are extremely fine fragments with characteristic diameters smaller than 1 mm. Due to the small particle size and the detection limitations of corium fragments in sodium with our X-Ray system, clouds of particles were detected instead of individual particles. In the second phase, the simulation of clouds of corium particles followed by the designing of phantoms (3D mock-ups) representing the 3-phase medium was carried out. Simulations of clouds of corium fragments in liquid sodium and vapor were performed using the CEA Cadarache in-house tool MODHERATO. Based on the results obtained from the simulations, certain phantoms were designed to conduct some physical experiments. These phantoms representative of the FCI interaction zone were manufactured to experimentally evaluate the performance of the radioscopy system and to facilitate the development and calibration of the image processing software. The third step of this work was dedicated to performing experiments with the phantoms and analyzing the radiographic images by developing an image processing algorithm. Experiments were carried out with phantoms in several configurations with the X-Ray radiography system at the CEA Cadarache KROTOS facility. The radioscopic images obtained were treated by developing a new comprehensive image processing and analysis code called PICSEL to identify the three phases composing the medium. Further verification and validation of the PICSEL software were carried out on a test conducted between corium and water at the KROTOS facility under the Euro-Chinese project “ALISA”. Thus, in this Ph.D. research, an X-Ray imaging system was qualified to visualize the corium-sodium interaction in the future PLINIUS-2-FR facility. A qualitative analysis of the images produced by this system was also performed using the PICSEL software to better characterize the evolution of the three-phase mixture and understand the FCI phenomenon, knowledge of which is deemed essential to improve the safety and designs of future sodium-cooled fast reactors.
Dans les réacteurs à neutrons rapides refroidis au sodium (RNR-Na), une défaillance dans le système de refroidissement du coeur ou de protection du réacteur peut conduire à un accident grave. Dans un tel scenario, les matériaux du coeur (combustible et acier) fondent pour former un mélange appelé corium susceptible d'interagir avec le réfrigérant (sodium). Une telle interaction (Fuel Coolant Interaction, FCI) peut générer des évènements énergétiques aptes à mettre en danger les structures du réacteur. La violence de l'explosion dépend essentiellement de l'état du mélange corium-sodium. Connaître les caractéristiques des trois phases en présence dans la zone d'interaction (corium, sodium liquide, vapeur de sodium) est donc crucial. Le manque de connaissances de la phénoménologie de l'interaction conduit à l'étudier au moyen de dispositifs expérimentaux. PLINIUS-2, la future plateforme expérimentale du CEA Cadarache consacrée aux grandes masses, sera dédiée à l'étude de la phénoménologie de l'interaction corium-réfrigérant (eau et sodium). L'objectif du présent travail est de développer, pour cette installation, un système d'imagerie basée sur des radiographies X afin de visualiser et de mieux comprendre l'interaction corium-sodium. Un algorithme de post-traitement de ces images a aussi été écrit afin de les analyser, d'en déduire la répartition des trois phases dans le système et de contribuer ainsi à l'amélioration de la modélisation numérique. Ce travail de thèse a été conduit en trois étapes. La première était consacrée à une étude bibliographique des expériences passées d'interaction corium-sodium et des mécanismes de fragmentation mis en jeu. Cette étude, complétée d'une analyse statistique des distributions de particules obtenue alors, a montré que les particules générées lors de ces expériences sont extrêmement fines avec des diamètres caractéristiques inférieurs au mm. Ces très petites tailles de particules combinées aux limites de détection de notre système d'imagerie nous ont amenés à travailler plutôt sur la détection de nuages de particules que de particules individuelles. Dans une deuxième étape, la simulation du nuage de particules de corium suivie de la conception de fantômes (maquettes 3D) représentant les trois phases du milieu ont été réalisées. Les simulations de nuages de fragments dans le sodium liquide et la vapeur ont été réalisées avec le logiciel CEA MODHERATO. Sur la base des résultats de ces calculs, certains fantômes ont été fabriqués afin de générer des images "réelles" à l'aide d'une chaîne d'imagerie existant au CEA. Ces fantômes représentatifs de la zone d'interaction corium-sodium ont été fabriqués pour faciliter le développement et la calibration du logiciel de traitement d'images. La troisième étape de cette thèse était dédiée à la conduite des expériences avec les fantômes 3D et au développement du logiciel de traitement des images ainsi obtenues. Les radiographies X des fantômes ont été générées à l'aide du système d'imagerie de l'installation KROTOS du CEA Cadarache. Les images ont ensuite été traitées avec le logiciel appelé PICSEL que nous avons développé afin de localiser les trois phases en présence dans la zone d'interaction. PICSEL a ensuite été appliqué à une expérience d'interaction corium-eau réalisée dans l'installation KROTOS dans le cadre du projet ALISA de collaboration Europe-Chine; ceci a permis une première validation du logiciel. Ainsi, lors de cette thèse, un système de radioscopie X a été défini pour visualiser l'interaction corium-sodium dans les expériences de la future installation PLINIUS-2 du CEA Cadarache. Une analyse qualitative des images produites par ce système (expériences menées avec des fantômes) est aussi réalisée avec le logiciel PICSEL développé lors de cette thèse afin de mieux caractériser le mélange, de mieux comprendre les mécanismes de l'interaction et de contribuer ainsi à l'amélioration de la sûreté des réacteurs à neutrons rapides.
