Investigation of Mitochondrial Dysfunctions in Fibroblasts of Patients with Deficiency in Iron-Sulfur Cluster Biogenesis or Lipoic Acid Synthesis Pathways
Exploration d'anomalies mitochondriales dans les fibroblastes de patients atteints de déficit dans les voies de biogenèse des centres fer-soufre ou de synthèse de l'acide lipoïque
The aim of this work is to study mitochondrial dysfunctions related to a defect of protein lipoylation in fibroblasts of 14 patients. These patients carry a point mutation in a gene encoding for a protein involved either in lipoic acid biosynthesis (LIPT1 or LIPT2) or in the mitochondrial pathway devoted to iron-sulfur cluster biogenesis (FDX1L, ISCA1, ISCA2, IBA57, NFU1, BOLA3) essential for maturation of mitochondrial Fe-S proteins such as lipoic acid synthase (LIAS). This work describes the second case of FDX1L deficiency and a patient with a new mutation in ISCA1 gene.We found that mitochondrial [4Fe-4S] proteins (mitochondrial aconitase, complexes I and II of the respiratory chain and LIAS) are mainly affected in fibroblasts of patients with defect in the mitochondrial Fe-S maturation pathway. Secondary, LIAS dysfunction leads to decreased lipoylation of PDHc and KGDHc, complexes involved in energy metabolism. Neither mitochondrial network nor oxidative stress biomarkers was modified in our study. Addition of exogenous lipoic acid did not rescue the mitochondrial deficiency.Protein expression profiles obtained in fibroblasts of patients suggest that NFU1, BOLA3 and IBA57 and also ISCA1, ISCA2 and IBA57 could function and interact together to form protein complexes.
Le but de cette thèse est d’étudier les modifications biochimiques mitochondriales liées à un défaut de lipoylation des protéines dans les fibroblastes de 14 patients. Ces patients sont porteurs d’une mutation dans un gène codant une des protéines impliquées soit dans la synthèse de l’acide lipoïque (LIPT1, LIPT2) soit dans la voie de biogenèse des centres Fe-S mitochondriale (FDX1L, ISCA1, ISCA2, IBA57, NFU1, BOLA3). La voie de biogenèse des centres Fe-S est nécessaire à la maturation des protéines Fe-S mitochondriales, dont la lipoic acid synthase (LIAS).Ces travaux ont permis d’étudier notamment un deuxième cas de déficit en FDX1L ainsi qu’un patient porteur d’une nouvelle mutation dans ISCA1. Les déficits dans la voie de la biogenèse des centres Fe-S observés chez les patients étudiés affectent principalement la maturation des protéines mitochondriales à centre [4Fe-4S] dont l’aconitase mitochondriale, les complexes I et II de la chaîne respiratoire et la LIAS, induisant ainsi un défaut de lipoylation d’enzymes clés du métabolisme énergétique (PDHc, KGDHc). Aucune atteinte du réseau mitochondrial ni de variations du stress oxydatif n’ont pu être mises en évidence. Finalement, l’ajout d’acide lipoïque exogène n’améliore pas les déficits observés.Les profils d’expression des protéines dans les fibroblastes des patients suggèrent que les protéines NFU1, BOLA3 et IBA57 ainsi que ISCA1, ISCA2 et IBA57 coopèrent entre elles de manière complexe.
