Spectral analysis and numerical simulation of cavities containing a negative material
Analyse spectrale et simulation numérique de cavités contenant un matériau négatif
This thesis achieves a theoretical and numerical studies of cavities partially filled with a negative material, that is a material for which the magnetic permeability and/or the electric permittivity (or at least their real part) become negative in some frequency ranges. This study is part of the main thrust of the work started in our team focusing on the electromagnetic wave propagation in presence of such negative materials, at a given fraquency. The purpose of this thesis is to take into account the frequency dispersion, that is the frequency dependence of the permeability and/or the permittivity, considering the frequency as the spectral parameter. We highlight the essential spectrum arising from the presence of negative material, as well as the resulting resonance phenomena, for different models describing this material. The theoretical study focuses on the case of polygonal bi-dimensional cavities for the Drude and the Lorentz models (with dissipation or not). The theoretical study of the simplest model (the non dissipative Drude model) is extended to the case of a curved (but regular) interface. This model is also the subject of a numerical study, aimed at exploring the effect of a finite element discretization of the theoretical problem, and thus highlight the difficulties to numerically notice some of the resonance phenomena.
Cette thèse réalise une étude théorique et numérique du spectre de cavités partiellement composées de matériau négatif, c'est-à-dire de matériau pour lequel la perméabilité magnétique et/ou la permittivité électrique (ou au moins leur partie réelle) deviennent négatives dans certaines plages de fréquences. Cette étude s'inscrit dans la continuité des travaux engagés dans notre laboratoire qui se concentrent sur la propagation des ondes électromagnétiques en présence de matériau négatif, à fréquence fixée. L'objectif de cette thèse est de prendre en compte la dispersion fréquentielle, autrement dit la dépendance en fréquence de la perméabilité et de la permittivité, en considérant la fréquence comme paramètre spectral. Nous mettons en évidence le spectre essentiel résultant de la présence de matériau négatif ainsi que les phénomènes de résonance qui en découlent, pour différents modèles décrivant ce matériau.L'étude théorique se concentre sur le cas de cavités bidimensionnelles polygonales pour les modèles de Drude et de Lorentz (avec et sans dissipation). L'étude théorique du modèle le plus simple (Drude non dissipatif) est étendue au cas d'une interface courbe (mais régulière).Ce modèle fait également l'objet d'une étude numérique, visant à explorer l'effet d'une discrétisation éléments finis du problème théorique, et ainsi mettre en avant les difficultés à observer numériquement certains des phénomènes de résonance.
Origin : Version validated by the jury (STAR)
