Quantitative study of retinal cones imaged by adaptive optics : structure and link with the visual function
Étude quantitative des cônes de la rétine imagés par optique adaptative : structure et lien avec la fonction visuelle
The high-resolved imagery delivered by the adaptive optic is used to form pictures of the retina at the cellular level and to diagnose and follow up on eyes pathologies, but also to improve knowledge of the anatomy, functions and mechanisms of the retina.First we defined the method that allows us to position the center of the fovea and to measure the density of the cones with the best repeatability. The center of the ellipse of higher densities makes it possible to position the center of the fovea. The cone density is measured in a region of interest of 80 x 80 pixels to an eccentricity measured on a montage established from pictures made every 2°.One of the fundamental aspects of this project is the creation of a normative clinical database linked to bio-markers (density, spacing and morphology of cones). Indeed it is necessary to provide quantitative measures of the structures visualized. This study made it possible to characterize the retinal structure of a healthy population with no retinal disease, so as to establish a reference of normality. This study also allowed us to answer questions left unanswered by the literature. The density of the cones differs sharply between the horizontal and vertical meridians. We have also observed that the axial length influences cone density expressed in metric unit but not in terms of visual angle, supporting the hypothesis that the retina is stretched with the lengthening of the eyeball. Finally, age does not seem to have an impact on cone density except at 2°.We then examined the relationship between peripheral visual acuity and cone spacing. It is known that midget ganglion cells are in charge of visual resolution. But, at the fovea, each cone connects, via bipolar cells, to a midget ganglion cell ON and OFF. This anatomical particularity makes the measurement of the cone spacing an observable substitute for ganglion cells thus allowing the link with visual acuity. We have therefore determined to what eccentricity the cones are no longer an observable substitute for ganglion cells. We found that visual acuity is governed by the arrangement of cones up to 2° of eccentricity, both in nasal and inferior retinas, supporting the idea that only 50% of foveal mRGCs determine VA (mRGC ON or OFF). Beyond this, cone spacing over-samples ganglion cells. Watson developed a model to predict visual acuity based on the mRGC spacing, itself derived from the cone spacing. The 50% model (mRGC ON or OFF) also predicts visual acuity in the inferior meridian at 4° and 6° of eccentricity. Along the nasal meridian, the 50% model underestimates visual acuity. Partial overlap of the mRGC ON + OFF receptive fields may be the cause.Finally, we measured the cone density in the central 48° along the horizontal meridian in two study groups, one with a history of myopic evolution (i.e. elongation of the eye) and the other without. To this date, there is only one study with in-vivo measurements of cone density beyond the central 15°. This study also allowed us to assert that during myopic evolution, the retina stretches uniformly in the measured area, excepted near the optic nerve head, where it appears that there is a stronger adhesion.
L’imagerie super-résolue délivrée par l’optique adaptative permet d’imager la rétine à l’échelle cellulaire et rentre au service du diagnostic et du suivi de pathologie de l’oeil mais aussi à une meilleure connaissance de l’anatomie, des fonctions et des mécanismes de la rétine.Dans un premier temps nous avons défini la méthode permettant de positionner le centre de la fovéa ainsi que de mesurer la densité des cônes avec la meilleure répétabilité. Le centre de l’ellipse de plus fortes densités permet de positionner le centre de la fovéa. La densité des cônes est mesurée dans une fenêtre de 80 par 80 pixels à une excentricité mesurée sur un montage établi à partir de clichés réalisés tous les 2°.Un des aspects fondamental de ce projet est la réalisation d’une base de données cliniques normatives liées à des bio-marqueurs (densité, espacement et morphologie des cônes). En effet il est nécessaire de fournir des mesures quantitatives des structures visualisées. Cette étude a permis de caractériser la structure rétinienne d’une population saine ne présentant aucune maladie rétinienne, de façon à établir un référentiel de normalité. Cette étude nous a aussi permis de répondre aux questions laissées sans réponse par la littérature. Nous avons constaté que la densité des cônes différait nettement entre les méridiens horizontaux et verticaux. Nous avons également observé que la longueur axiale influait sur la densité des cônes exprimée en unité de surface mais pas en terme d'angle visuel, supportant l'hypothèse que la rétine s'étirait avec l'allongement du globe oculaire. Enfin, l'âge ne semble pas avoir d'impact sur la densité des cônes excepté à 2°.Nous nous sommes ensuite intéressé au lien entre l’acuité visuelle périphérique et l’espacement des cônes. Il est connu que les cellules ganglionnaires midgets (mRGC) sont responsables de la résolution visuelle. Mais, au niveau de la fovéa, chaque cône se connecte, via des cellules bipolaires, à une mRGC ON et OFF. Cette particularité anatomique rend la mesure de l’espacement entre les cônes un substitut observable aux cellules ganglionnaires permettant ainsi le lien avec l'acuité visuelle. Nous avons donc déterminé jusqu'à quelle excentricité les cônes ne sont plus un substitut observable des cellules ganglionnaires. Nous avons constaté que l’acuité visuelle est régit par l’espacement des cônes jusqu’à 2° d’excentricité, à la fois en rétine nasale et inférieure, soutenant l'idée que seulement 50% des mRGC fovéale détermine l’acuité visuelle (mRGC ON ou OFF). Au delà, l’espacement des cônes surestime l’acuité visuelle. Watson a développé un modèle permettant de prédire l’acuité visuelle sur la base de l’espacement entre les mRGC lui-même dérivé de l’espacement entre les cônes. Le modèle 50% (mRGC ON ou OFF) prédit également l’acuité visuelle dans le méridien vertical (inférieur) à 4° et 6° d'excentricité. Le long du méridien nasal, le modèle 50% sous-estime l’acuité visuelle. Un chevauchement partiel des champs récepteurs des mRGC ON + OFF pourrait en être la cause. Nous avons ensuite mesuré la densité des cônes dans les 48° centraux le long du méridien horizontal dans deux groupes, l’un présentant une histoire d’évolution myopique (i.e. allongement de l'oeil) et l'autre non. À ce jour, il n'existe qu’une seule étude ayant des mesures in-vivo de la densité des cônes au delà des 15° centraux. Cette étude nous a également permis d'affirmer que lors de l'évolution myopique, la rétine s’étirerait de manière uniforme dans la zone mesurée, excepté proche de la tête du nerf optique, où il semblerait qu'il y ait une adhérence plus forte.
Origine | Fichiers produits par l'(les) auteur(s) |
