Usuba, Optimizing Bitslicing Compiler - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2020
Usuba, Compilateur Bitslicing Optimisant
Bitslicing is a technique commonly used in cryptography to implement high-throughput parallel and constant-time symmetric primitives. However, writing, optimizing and protecting bitsliced implementations by hand are tedious tasks, requiring knowledge in cryptography, CPU microarchitectures and side-channel attacks. The resulting programs tend to be hard to maintain due to their high complexity. To overcome those issues, we propose Usuba, a high-level domain-specific language to write symmetric cryptographic primitives. Usuba allows developers to write high-level specifications of ciphers without worrying about the actual parallelization: an Usuba program is a scalar description of a cipher, from which the Usuba compiler (Usubac) automatically produces vectorized bitsliced code. When targeting high-end Intel CPUs, the Usubac applies several domain-specific optimizations, such as interleaving and custom instruction-scheduling algorithms. We are thus able to match the throughputs of hand-tuned assembly and C implementations of several widely used ciphers. Futhermore, in order to protect cryptographic implementations on embedded devices against side-channel attacks, we extend our compiler in two ways. First, we integrate into Usubac state-of-the-art techniques in higher-order masking to generate implementations that are provably secure against power-analysis attacks. Second, we implement a backend for SKIVA, a custom 32-bit CPU enabling the combination of countermeasures against power-based and timing-based leakage, as well as fault injection.
Le bitslicing est une technique utilisée pour implémenter des primitives cryptographiques efficaces et s'exécutant en temps constant. Cependant, écrire, optimiser, et sécuriser manuellement des programmes bitslicés est une tâche fastidieuse, nécessitant des connaissances en cryptographie, en microarchitecture des processeurs et en attaques par canaux cachés. Afin de remédier à ces difficultés, nous proposons Usuba, un langage dédié permettant d'implémenter des algorithmes de cryptographie symétrique. Usuba permet aux développeurs d'écrire des spécifications de haut niveau sans se soucier de leur parallélisation: un programme Usuba est une description scalaire d'une primitive, à partir de laquelle le compilateur Usuba, Usubac, produit automatiquement un code bitslicé et vectorisé. Afin de produire du code efficace pour les processeurs haut de gamme, Usubac applique plusieurs optimisations spécialement conçues pour les primitives cryptographiques, telles que l'entrelacement et l'ordonnancement d'instructions. Ainsi, le code produit par notre compilateur offre des performances comparables à du code assembleur ou C optimisé à la main. De plus, afin de générer des implémentations sécurisées contre des attaques par canaux cachés, nous proposons deux extensions de Usubac. Lorsque les attaques par analyse de courant sont un risque à considérer, Usubac est capable de protéger les implémentations qu'il produit à l'aide de masquage booléen. Si, additionellement, des attaques par injection de fautes doivent être prévenues, alors Usubac peut générer du code pour SKIVA, un processeur 32-bit offrant des instructions permettant de combiner des contre-mesures pour du code bitslicé.
thesis.pdf (4.76 Mo) Télécharger le fichier
tel-03133456 , version 1 (06-02-2021)
tel-03133456 , version 2 (19-10-2021)
  • HAL Id : tel-03133456 , version 1
Darius Mercadier. Usuba, Optimizing Bitslicing Compiler. Programming Languages [cs.PL]. Sorbonne Université (France), 2020. English. ⟨NNT : ⟩. ⟨tel-03133456v1⟩
275 Consultations
1199 Téléchargements
