Identification des gènes impliqués dans la coopération oncogénique avec BCR-ABL1 dans la Leucémie Myéloïde Chronique - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2018
Identifying genes involved in the oncogenic BCR-ABL1cooperation in the Chronic Myeloid Leukemia
Chronic myeloid leukemia (CML) was the first human cancer to be consistently associated with a chromosomal abnormality: the Philadelphia chromosome. The resulting BCR-ABL1 fusion gene encodes a tyrosine kinase with deregulated activity. Tyrosine kinase inhibitors (TKIs) inactivating the BCR-ABL protein represent the most successful targeted therapy for CML in chronic phase. However, advanced CML does not respond well to TKIs treatment. The mechanisms underlying the progression of CML are not well understood. Therefore, the discovery of genes that cooperate with the BCR-ABL1 oncogene, which could explain the progression of CML to advanced phases, is required for the identification of novel therapeutic targets of CML. We propose to establish a human cellular model system that allows the identification of genes that are able to cooperate with the oncogene BCR-ABL1 for full tumoral transformation. This system relies on the expression of BCR-ABL1 and the generation of gene knock-out by using the CRISPR-Cas9 technology. Identification of genes cooperating with BCR-ABL1 will permit the creation of cellular model systems for identifying drugs that are able to treat CML in final phases. Secondly, we performed a detailed study of TP53 function. This gene is mutated in more than 50% of all cancer types. It is therefore crucial to understand the impact of its inactivation in human fibroblast cells. The CRISPR/Cas9 system was used to inactivate this gene. Wild-type and TP53 knock-out cells subsequently underwent nutlin-3a treatment. This molecule blocks the interaction between p53 and its regulator: MDM2. Transcriptomic analyses were performed to further study p53 regulated genes, and also to discover other potential nutlin-3a targets.
La leucémie myéloïde chronique (LMC) a été le premier cancer humain associé à une anomalie chromosomique : le chromosome de Philadelphie. Le gène de fusion BCR-ABL1 résultant code pour une tyrosine kinase ayant une activité dérégulée. Les inhibiteurs de tyrosine kinase (ITKs), qui inactivent la protéine BCR-ABL1, représentent la thérapie ciblée la plus efficace pour la LMC en phase chronique. Cependant, la LMC en phase avancée ne répond pas bien au traitement par les ITKs. Les mécanismes sous-jacents à la progression de la LMC ne sont pas bien compris. Par conséquent, la découverte de gènes qui coopèrent avec l’oncogène BCR-ABL1, et qui pourraient expliquer la progression de la LMC vers des phases avancées, est nécessaire pour l’identification de nouvelles cibles thérapeutiques de la LMC. Nous proposons d'établir un modèle cellulaire humain permettant l'identification de gènes capables de coopérer avec l'oncogène BCR-ABL1 pour une transformation tumorale complète. Ce système repose sur l'expression de BCR-ABL1 et l'inactivation d'autres gènes en particulier à l'aide de la technologie CRISPR-Cas9. L'identification des gènes coopérant avec BCR-ABL1 permettra la création de modèles cellulaires pour faciliter la sélection de médicaments capables de traiter la LMC dans les phases finales. Dans un second temps, une étude approfondie du gène TP53 a été menée. Ce gène étant muté dans plus de 50% des cancers, il est important de déterminer les conséquences de son inactivation dans des fibroblastes humains non tumoraux. La technologie CRISPR-Cas9 a été utilisée afin d’inactiver ce gène en particulier. Puis les cellules exprimant la forme sauvage ou la forme inactivée de p53 ont subi un traitement à la nutline-3a. Cette molécule empêche l’interaction du facteur de transcription p53 avec son inhibiteur MDM2. Des analyses transcriptomiques ont alors permis d’identifier d’une part les cibles aspécifiques de la nutline-3a et d’autre part les gènes cibles de p53 dans cette lignée de fibroblaste.
ROUSSEAU_EMILIE_2018.pdf (5.69 Mo) Télécharger le fichier
tel-03198642 , version 1 (15-04-2021)
  • HAL Id : tel-03198642 , version 1
Emilie Rousseau. Identification des gènes impliqués dans la coopération oncogénique avec BCR-ABL1 dans la Leucémie Myéloïde Chronique. Médecine humaine et pathologie. Université de Bordeaux, 2018. Français. ⟨NNT : 2018BORD0281⟩. ⟨tel-03198642⟩
271 Consultations
301 Téléchargements
