2D and 3D Geometric Attributes Estimation in Images via deep learning - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2021
Estimation d'attributs Géométriques 2D et 3D dans des Images par Apprentissage Profond
The visual perception of 2D and 3D geometric attributes (e.g. translation, rotation, spatial size and etc.) is important in robotic applications. It helps robotic system build knowledge about its surrounding environment and can serve as the input for down-stream tasks such as motion planning and physical intersection with objects.The main goal of this thesis is to automatically detect positions and poses of interested objects for robotic manipulation tasks. In particular, we are interested in the low-level task of estimating occlusion relationship to discriminate different objects and the high-level tasks of object visual tracking and object pose estimation.The first focus is to track the object of interest with correct locations and sizes in a given video. We first study systematically the tracking framework based on discriminative correlation filter (DCF) and propose to leverage semantics information in two tracking stages: the visual feature encoding stage and the target localization stage. Our experiments demonstrate that the involvement of semantics improves the performance of both localization and size estimation in our DCF-based tracking framework. We also make an analysis for failure cases.The second focus is using object shape information to improve the performance of object 6D pose estimation and do object pose refinement. We propose to estimate the 2D projections of object 3D surface points with deep models to recover object 6D poses. Our results show that the proposed method benefits from the large number of 3D-to-2D point correspondences and achieves better performance. As a second part, we study the constraints of existing object pose refinement methods and develop a pose refinement method for objects in the wild. Our experiments demonstrate that our models trained on either real data or generated synthetic data can refine pose estimates for objects in the wild, even though these objects are not seen during training.The third focus is studying geometric occlusion in single images to better discriminate objects in the scene. We first formalize geometric occlusion definition and propose a method to automatically generate high-quality occlusion annotations. Then we propose a new occlusion relationship formulation (i.e. abbnom) and the corresponding inference method. Experiments on occlusion reasoning benchmarks demonstrate the superiority of the proposed formulation and method. To recover accurate depth discontinuities, we also propose a depth map refinement method and a single-stage monocular depth estimation method.All the methods that we propose leverage on the versatility and power of deep learning. This should facilitate their integration in the visual perception module of modern robotic systems.Besides the above methodological advances, we also made available software (for occlusion and pose estimation) and datasets (of high-quality occlusion information) as a contribution to the scientific community
La perception visuelle d'attributs géométriques (ex. la translation, la rotation, la taille, etc.) est très importante dans les applications robotiques. Elle permet à un système robotique d'acquérir des connaissances sur son environnement et peut fournir des entrées pour des tâches telles que la localisation d'objets, la compréhension de scènes et la planification de trajectoire. Le principal objectif de cette thèse est d'estimer la position et l'orientation d'objets d'intérêt pour des tâches de manipulation robotique. En particulier, nous nous intéressons à la tâche de bas niveau d'estimation de la relation d'occultation, afin de mieux pouvoir discriminer objets différents, et aux tâches de plus haut niveau de suivi visuel d'objets et d'estimation de leur position et orientation. Le premier axe d'étude est le suivi (tracking) d'un objet d'intérêt dans une vidéo, avec des locations et tailles correctes. Tout d'abord, nous étudions attentivement le cadre du suivi d'objet basé sur des filtres de corrélation discriminants et proposons d'exploiter des informations sémantiques à deux niveaux~: l'étape d'encodage des caractéristiques visuelles et l'étape de localisation de la cible. Nos expériences démontrent que l'usage de la sémantique améliore à la fois les performances de la localisation et de l'estimation de taille de l'objet suivi. Nous effectuons également des analyses pour comprendre les cas d'échec. Le second axe d'étude est l'utilisation d'informations sur la forme des objets pour améliorer la performance de l'estimation de la pose 6D des objets et de son raffinement. Nous proposons d'estimer avec un modèle profond les projections 2D de points 3D à la surface de l'objet, afin de pouvoir calculer la pose 6D de l'objet. Nos résultats montrent que la méthode que nous proposons bénéficie du grand nombre de correspondances de points 3D à 2D et permet d'obtenir une meilleure précision des estimations. Dans un deuxième temps, nous étudions les contraintes des méthodes existantes pour raffiner la pose d'objets et développons une méthode de raffinement des objets dans des contextes arbitraires. Nos expériences montrent que nos modèles, entraînés sur des données réelles ou des données synthétiques générées, peuvent raffiner avec succès les estimations de pose pour les objets dans des contextes quelconques. Le troisième axe de recherche est l'étude de l'occultation géométrique dans des images, dans le but de mieux pouvoir distinguer les objets dans la scène. Nous formalisons d'abord la définition de l'occultation géométrique et proposons une méthode pour générer automatiquement des annotations d'occultation de haute qualité. Ensuite, nous proposons une nouvelle formulation de la relation d'occultation (abbnom) et une méthode d'inférence correspondante. Nos expériences sur les jeux de tests pour l'estimation d'occultations montrent la supériorité de notre formulation et de notre méthode. Afin de déterminer des discontinuités de profondeur précises, nous proposons également une méthode de raffinement de cartes de profondeur et une méthode monoculaire d'estimation de la profondeur en une étape. En utilisant l'estimation de relations d'occultation comme guide, ces deux méthodes atteignent les performances de l'état de l'art. Toutes les méthodes que nous proposons s'appuient sur la polyvalence et la puissance de l'apprentissage profond. Cela devrait faciliter leur intégration dans le module de perception visuelle des systèmes robotiques modernes. Outre les avancées méthodologiques mentionnées ci-dessus, nous avons également rendu publiquement disponibles des logiciels (pour l'estimation de l'occlusion et de la pose) et des jeux de données (informations de haute qualité sur les relations d'occultation) afin de contribuer aux outils offerts à la communauté scientifique
TH2021ENPC0005.pdf (67.41 Mo) Télécharger le fichier
tel-03224484 , version 1 (11-05-2021)
  • HAL Id : tel-03224484 , version 1
Xuchong Qiu. 2D and 3D Geometric Attributes Estimation in Images via deep learning. Signal and Image Processing. École des Ponts ParisTech, 2021. English. ⟨NNT : 2021ENPC0005⟩. ⟨tel-03224484⟩
261 Consultations
41 Téléchargements
