Study of the effects of collisions in the infrared spectra of the atmospheric molecule CH₃I, a molecule of atmospheric interest
Étude des effets des collisions dans les spectres infrarouges de CH₃I, molécule d’intérêt atmosphérique
The work presented in this manuscript is devoted to the study of the effects of collisions in the infrared spectra of CH₃I, which is an important source of iodine, which is a catalyst for ozone destruction. Good modelling of its absorption spectrum is therefore essential for atmospheric concentration measurements. In international databases, the band ν6 is not mentioned due to the lack of spectroscopic parameters. Being very intense and localized in the atmospheric window of 11 μm, the ν6 band could be used for future IR detection of CH₃I, by instruments probing in the IR, such as the IASI-NG instrument under preparation. But first, it is necessary to provide the spectroscopic parameters of CH₃I, using laboratory spectroscopy. It is in this context that our work has been carried out. The manuscript consists of five parts. The first part concerns the spectroscopic properties of the CH3I molecule. The second part is dedicated to the apparatus, with a description of the Bruker IFS125HR FTIR spectrometer. In the third part, we present the results of the line intensities and self-broadening coefficients that are extracted from the recorded spectra. The fourth part presents the results obtained on N₂, O₂ broadening and shift coefficients. The last part is devoted to the interpretation of the collisional widening measurements, previously obtained using theoretical calculations. The dependence of these parameters on the quantum numbers J and K has been studied.
Les travaux présentés dans ce manuscrit sont consacrés à l’étude des effets des collisions dans les spectres infrarouges de CH₃I qui est une source importante de l’iode qui est un catalyseur de la destruction d’ozone. Une bonne modélisation de son spectre d’absorption est donc essentielle pour les mesures de concentration atmosphérique. Dans les bases de données internationales, la bande ν6 n’est pas mentionnée en raison du manque de paramètres spectroscopiques. Étant très intense et localisée dans la fenêtre atmosphérique de 11 μm, la bande ν6, pourrait servir à une future détection IR de CH₃I, par des instruments sondant dans l’IR, comme l’instrument IASI-NG en cours de préparation. Mais auparavant, il est nécessaire de fournir les paramètres spectroscopiques de CH₃I, grâce à la spectroscopie de laboratoire. C’est dans ce contexte que notre travail s’est inscrit. Le manuscrit comporte cinq parties. La première partie concerne les propriétés spectroscopiques de la molécule CH₃I. La deuxième partie est dédiée à l’appareillage, avec la description du spectromètre IRTF Bruker IFS125HR. Dans la troisième partie, nous exposons les résultats des intensités et des auto-élargissements de raies qui sont extrait à partir des spectres enregistré. La quatrième partie présente les résultats obtenus sur les coefficients d’élargissement et le déplacement collisionnel par N₂ et O₂. La dernier partie est consacrée à l’interprétation des mesures des élargissements collisionnels, obtenus précédemment à l’aide des calculs théoriques. La dépendance de ces paramètres en fonction des nombres quantiques J et K a été étudiée.
Mots clés
Methyl iodide
High-Resolution Fourier transform spectroscopy
Line positions
Line intensities
Self-Broadening coefficients
N₂ collisional broadening
O₂ collisional broadening
Shift coefficients
Theoretical broadening coefficients
J and K dependence.
Iodure de méthyle
Spectroscopie à haute résolution par transformée de Fourier
Positions des raies
Intensités des raies
Coefficients d’auto-Élargissement
Coefficients d’élargissement par N₂
Coefficients d’élargissement par O₂
Déplacement de raie
Coefficients d’élargissement théorique
Dépendance en J et K
Physique [physics]
