Morpho-statistical study of social networks. Application to inter-organisational collaborations
Étude morpho-statistique des réseaux sociaux. Application aux collaborations inter-organisationnelles
Decentralised collaborative applications address privacy, availability and security issues related to centralised collaborative platforms. Such applications are based on a peer-to-peer communication paradigm according to which all users are directly connected to one another. Collaborations tend to widen and spread beyond the borders of organisations. Under these circumstances, it is necessary to guarantee to users the control over their data, while keeping collaboration available. To that end, the social network that has built between collaborators may be used as topology. Lack of information on this trusted network leads us to develop an approach to study its morphological properties. In this thesis, we develop and implement an approach to study the social structure of interactions in the context of inter-organisational collaborations. We propose a stochastic approach based on Exponential Random Graph Models (ERGM) and spatial models. We define a formalism that highlights the structure of interactions and integrates the organisational dimension. We propose to use a Bayesian inference method, ABC Shadow, to overcome the issues related to the parameters estimation. This approach is applied to a real case study: the collaborations initiated by researchers in a laboratory. In particular, it highlights the low tendency for a researcher to create collaborative links with other laboratories. We show that this approach can be applied to other kinds of social interactions, such as interactions between pupils of a primary school. Finally, we present a parallelisation strategy of the Gibbs sampler aimed at processing larger graphs in a reasonable time.
Les applications collaboratives décentralisées permettent de répondre aux problèmes de confidentialité, de disponibilité et de sécurité inhérents aux plateformes collaboratives centralisées. Elles reposent sur un paradigme de communication pair-à-pair selon lequel tous les utilisateurs sont directement connectés les uns aux autres. Les collaborations ayant tendance à s'élargir et dépasser les frontières des organisations, il est nécessaire de garantir aux utilisateurs le contrôle sur leurs données tout en assurant la disponibilité de la collaboration. Pour ce faire, il est possible d'utiliser comme topologie le réseau social qui s'est tissé entre les collaborateurs. Le manque d'information sur ce maillage de confiance nous amène à développer une approche pour étudier ses propriétés morphologiques. Dans cette thèse, nous développons et mettons en œuvre une approche permettant d'étudier la structure sociale des interactions dans le cadre de collaborations inter-organisationnelles. Nous proposons une approche stochastique qui s'inspire des Exponential Random Graph Models (ERGM) et des modèles spatiaux. Nous définissons un formalisme qui met en avant la structure des interactions et intègre la dimension organisationnelle. Nous proposons d'utiliser une méthode d'inférence bayésienne, ABC Shdadow, pour contourner les difficultés liées à l'estimation de ce modèle. Cette approche est mise en œuvre sur un exemple réel : les collaborations initiées par les chercheurs d'un laboratoire. Elle permet notamment de montrer la faible propension, pour un chercheur, à tisser des liens avec d'autres laboratoires. Nous montrons que cette approche peut être appliquée à d'autres types d'interactions sociales, comme les interactions entre les enfants d'une école primaire. Enfin, nous présentons une stratégie de parallélisation de l'échantillonneur de Gibbs visant à traiter des graphes de plus grande taille dans un temps raisonnable.
