Afrique réelle et Afrique rêvée dans les romans francophones subsahariens contemporains : L'exemple de "Balbala" et "Aux Etats-Unis d'Afrique" d'Abdourahman Ali Waberi ; "Le Baobab fou" et "La Pièce d'or" de Ken Bugul - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2016
Real Africa and Africa dreamt in contemporary Sub-Saharian novels : The example of "Balbala" and "Aux Etats-Unis d'Afrique" written by Abdourahman Ali Waberi ; "Le Baobab Fou" and "La Pièce d'or" written by Ken Bugul
Our study which is focused on the French literature is titled: Real Africa and Africa dreamt in contemporary Sub-Saharan novels. The example of: “Balbala" and "Aux Etats-Unis d'Afrique" written by Waberi (A.A.); "Le Baobab fou" and "La Pièce d'or" written by Ken Bugul. The importance of this research consists in observing the process of Africa's reconfiguration in the works mentioned above. It is not only about analyzing the real, dreamt, or ambivalent Africa, it is about observing textual methods for which the passage from a real Africa to a dreamt Africa is possible and, how this back and forth of a universe that is lead in a third space can be perceived as alternative Africa that the authors of these texts aspire. Furthermore, these texts become the diagnostic tools of the failings of the society and equally help to provide preemptive solutions on the operation of the continent. To conduct this study, we used a double methodology such as the textual poetic of Gerard Genette and the interpretative semiotic revisited by Louis Hebert. At the end of ours analyses we keep in mind that in these texts the authors express an alternative Africa. They present it as she is, and also the way they would like it to be. But such vision of the world isn't it a simple utopia which falls under the unattainable ?
Notre étude qui reste résolument tournée vers les littératures francophones a pour titre : Afrique réelle et Afrique rêvée dans les romans francophones subsahariens contemporains. L’exemple de : "Balbala", "Aux Etats-Unis d’Afrique" de Waberi (A.A.) et "Le Baobab fou" et "La Pièce d’or" de Ken Bugul. Le tout de cette recherche consiste à observer le processus de reconfiguration de l’Afrique dans les œuvres susmentionnées. Il ne s’agit pas simplement d’analyser l’Afrique réelle, rêvée ou ambivalente. Il s’agit plus difficilement d’observer les procédés textuels par lesquels, le passage d’une Afrique réelle à une Afrique rêvée s’opère et, comment ce va et vient d’un univers à un autre débouche sur un troisième espace qui peut être perçu comme l’Afrique alternative dont aspire en réalité nos auteurs. De plus ces œuvres deviennent de véritables lieux d’une problématisation allant de la mise en évidence des travers de la société à la proposition des solutions préemptives sur le fonctionnement du continent. Pour mener cette étude nous avons utilisé une double méthodologie dont la poétique textuelle de Gérard Genette et la sémiotique interprétative revisitée par Louis Hébert. De ces analyses nous retenons que, dans ces œuvres les auteurs expriment une Afrique alternative. Ils la traduisent telle qu’elle est mais aussi telle qu’ils voudraient qu’elle soit. Mais cette vision du monde n’est-elle pas une simple utopie qui relève de l’ordre de l’inatteignable ?
2016LIMO0024.pdf (2.87 Mo) Télécharger le fichier
tel-03264176 , version 1 (18-06-2021)
  • HAL Id : tel-03264176 , version 1
Aude Mayindza. Afrique réelle et Afrique rêvée dans les romans francophones subsahariens contemporains : L'exemple de "Balbala" et "Aux Etats-Unis d'Afrique" d'Abdourahman Ali Waberi ; "Le Baobab fou" et "La Pièce d'or" de Ken Bugul. Littératures. Université de Limoges, 2016. Français. ⟨NNT : 2016LIMO0024⟩. ⟨tel-03264176⟩
Collections
UNILIM STAR IR-SHS
203 Consultations
440 Téléchargements
