Constant Time Decoding of Quantum Expander Codes and Application to Fault-Tolerant Quantum Computation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2019
Décodage des Codes Expanseurs Quantiques et Application au Calcul Quantique Tolérant aux Fautes
Fault tolerant quantum computation is a technique to perform reliable quantum computation using noisy components. In this context, quantum error correcting codes are used to keep the amount of errors under a sustainable threshold. One of the main problems of this field is to determine the minimum cost, in terms of memory and time, which is needed in order to transform an ideal quantum computation into a fault-tolerant one. In this PhD thesis, we show that the family of quantum expander codes and the small-set-flip decoder can be used in the construction of ref. [46] to produce a fault-tolerant quantum circuit with constant space overhead. The error correcting code family and the decoder that we study has been introduced in ref. [67] where an adversarial error model was examined. Based on the results of this article, we analyze quantum expander codes subjected to a stochastic error model which is relevant for fault-tolerant quantum computation [38], [37]. In addition, we show that the decoding algorithm can be parallelized to run in constant time. This is very relevant to prevent errors from accumulating while the decoding algorithm is running. Beyond the theoretical results described above, we perform a numerical analysis of quantum expander codes to measure their performance in practice [49]. The error model used during these simulations generates X and Z type errors on the qubits with an independent and identically distributed probability distribution. Our results are promising because they reveal that these constant rate codes have a decent threshold and good finite length performance.
Le calcul quantique tolérant aux fautes est un ensemble de techniques dont le but est d’effectuer des calculs quantiques de manière fiable en utilisant des composants bruités. Dans ce contexte, l’utilisation de codes correcteurs quantiques maintient le nombre d’erreurs présentes dans le système en dessous d’un seuil tolérable. L’un des principaux problèmes de ce domaine est d’évaluer le coût minimum (en mémoire et en temps) nécessaire pour transformer un calcul quantique idéal en un calcul tolérant aux fautes. Dans cette thèse, nous montrons que la famille des codes expanseurs quantiques associée à l’algorithme de décodage small-set-flip peut être utilisée dans la construction de ref. [46] pour réaliser du calcul quantique tolérant aux fautes avec coût constant en mémoire. La famille de codes correcteurs ainsi que le décodeur que nous étudions ont été introduits dans ref. [67] où un modèle de bruit adverse est considéré. En nous appuyant sur les résultats de cet article, nous analysons le comportement des codes expanseurs quantiques face à un modèle de bruit stochastique qui est pertinent dans le cadre du calcul tolérant aux autes [38], [37]. De plus, nous montrons que l’algorithme de décodage peut être parallélisé pour fonctionner en temps constant. Cette propriété est essentielle pour éviter que les erreurs ne s’accumulent pendant que l’algorithme est exécuté. Au-delà des résultats théoriques décrits ci-dessus, nous avons effectué une analyse numérique des codes expanseurs quantiques dans le but d’évaluer leurs performances en pratique [49]. Le modèle de bruit choisi pour ces simulations consiste à générer des erreurs de types X et Z de manière indépendante et identiquement distribuée sur les qubits. Les résultats obtenus pour ces codes de rendement constant sont prometteurs puisque nos simulations montrent que leur seuil est décent et que leurs performances à taille finie sont bonnes.
thesis.pdf (1.73 Mo) Télécharger le fichier
tel-03364419 , version 1 (22-12-2019)
tel-03364419 , version 2 (31-12-2020)
tel-03364419 , version 3 (04-10-2021)
  • HAL Id : tel-03364419 , version 1
Antoine Grospellier. Constant Time Decoding of Quantum Expander Codes and Application to Fault-Tolerant Quantum Computation. Quantum Physics [quant-ph]. Sorbonne universités, 2019. English. ⟨NNT : ⟩. ⟨tel-03364419v1⟩
721 Consultations
1057 Téléchargements
