Mathematical understanding among sugar cane farmers
LA JUSTE MESURE Une étude des compétences mathématiques des travailleurs de la canne à sucre du Nordeste du Brésil dans le domaine de la mesure
This study is aimed at analyzing the cognitive functioning of illiterate subjects or subjects with little schooling in the mathematical domain. These subjects, while working as sugar-cane planters, have to deal with mathematical computations involving the determination of the area of different plots of land, and to develop, without any direct help from school instruction, an understanding of mathematical relations. This understanding, however, is developed through the use of non-precise schemes, which, depending on the measures chosen to be included in the computation, may sub estimate or overestimate the final results. Twenty-one sugar cane workers, occupying different levels in the hierarchy of the sugar cane plantation, from cane cutters to supervisors and administrators, took part in the study. Following an ethnographic study of the work in the plantation, data were collected in three phases. In phase I subjects were individually interviewed about how they would compute the area of plots of measures spontaneously given by themselves, followed by the computation of areas of plots with measures suggested by the interviewer. In this phase, the precise shapes of the plots (quadrilaterals or triangles) were not drawn. Phase II consisted of a more formal interview in which the subject was presented, in view of drawings on paper, with the same perimeter, but different surfaces. They had to: (a) compute the area of quadrilateral and triangles representing plots of land with all measures indicated; (b) compare the surfaces of figures representing plots of land; and (c) double the area of a square. Phase III consisted of field observations and interviews to clarify some points raised by the results of previous phases, and determine the most common types of plots that workers deal with in their everyday activities. Results of the first phase show the constant use of non-precise computational schemes with choice of elements that overestimate (in the case of cane cutters) or sub estimate (in the case of supervisors and administrators) the area to be worked. In the second, more formal phase, new strategies, aimed at correcting distortions increased by the irregular shape of plots were found. Finally, in the third phase, we found that workers at all levels seem to be aware of the distortions resulting from the use of a wrong formula and that these distortions can be compensated by other social mechanisms. The choice of measures in this context may be interpreted as a result of the particular social interactions in which computations take place, thus illustrating how the development of mathematical understanding is intertwined with the cultural context involved in the situation where problems are solved. Results are discussed in terms of methodological and conceptual issues relating culture and the development of mathematical knowledge.
L'objectif de cette recherche est d'analyser le fonctionnement cognitif des sujets analphabètes ou peu scolarisés, dans le domaine de la mesure. Les travailleurs de la canne à sucre du Nordeste du Brésil semblent développer une compréhension des relations mathématiques impliquées dans des activités de mesure spécifiques du travail à partir de l'usage d'un système régional de calcul d'aire induisant des surestimations systématiques. Toutefois, cette compréhension se révèle à travers l'emploi de schèmes non précis qui peuvent surestimer plus ou moins les aires en fonction des valeurs numériques choisies pour le calcul. Vingt et un sujets de différents niveaux hiérarchiques (ouvriers et employés) ont participé à cette recherche. A partir d'une étude ethnographique préliminaire des situations pratiques de travail dans la communauté, les données ont été recueillies au cours de trois phases. La phase I, plus exploratoire, impliquait des observations naturalistes et des entretiens individuels. Ces derniers concernaient les données individuelles des sujets et les données spécifiques à la résolution de problèmes de mesure dans le travail. Les sujets devaient calculer l'aire de terrains quadrilatères et triangulaires, dont les mesures étaient proposées par eux-mêmes, comme exemples, et ensuite par le chercheur. Dans cette phase la figure géométrique correspondant aux mesures proposées n'était pas présentée par le chercheur mais sollicitée du sujet qui devait la dessiner. .Dans la phase II, "d'expérimentation" plus formelle, nous avons introduit des figures géométriques de même périmètre mais de surfaces différentes, qui ont été dessinées sur un papier ou construites avec une ficelle nouée. Nous avons demandé aux sujets de: (a) calculer l'aire des quadrilatères et des triangles qui représentaient des terrains dont les mesures étaient indiquées; (b) comparer les surfaces de ces figures; et (c) doubler l'aire d'un carré et chercher la valeur numérique du nouveau carré. De plus, dans cette phase, nous avons proposé des problèmes de mesure dont le contenu était familier et non familier. Nous avons voulu analyser la portée et les limites de compétences mathématiques des sujets. La phase III a consisté en observations plus ponctuelles concernant le calcul de surface dans des activités réelles de travail, et a permis l'observation de la facette administrative de l'usine. Les résultats de la première phase révèlent l'emploi de schèmes non précis de calcul avec un choix des mesures qui surestiment les surfaces (davantage dans le cas des ouvriers que dans le cas des employés). Dans la phase II, plus formelle, nous avons vu apparaître de nouvelles stratégies de calcul d'aire susceptibles de corriger les distorsions les plus importantes. En ce qui concerne les problèmes proposés, leur contenu semble jouer un rôle important dans les schèmes évoqués et induisent un nombre élevé de refus pour les problèmes de contenu non familier. Enfin, dans la troisième phase, les sujets compensent les distorsions résultant de l'emploi de la formule régionale par des processus de négociation. Les résultats montrent que les compétences mathématiques sont construites socialement et transmises dans des structures sociologiquement repérables.
