Simulation of water-vapor two-phase flows with non-condensable gas.
Simulation d'écoulements diphasiques eau-vapeur en présence d'incondensables.
This PhD work deals with the modeling and simulation of multiphase flows that could appear during accidental scenarios which may hypothetically affect a pressurized water reactor. These flows are mainly made up of water, whose gaseous phase is composed of a miscible mixture of non-condensable gases and steam, and which may include in the case of a steam explosion an immiscible third phase formed by molten corium. The considered models aimed to simulate very abrupt phase transitions, during which liquid water and steam are likely to persist in an observable manner outside the conditions of thermodynamic equilibrium. Different aspects of the modeling process are addressed in this work.
First, thermodynamic closures are studied by defining realistic and admissible phasic equations of state. A homogeneous two-phase model without non-condensable gases was first equipped with a look-up table based on the IAPWS-IF97 formulation. Since the look-up table was built to fulfill the Gibbs relation, the verification of the model via mesh convergence studies could be achieved. This work also pointed out that the look-up table required a very robust numerical convection scheme, such as the relaxation scheme proposed by C. Chalons and J.-F. Coulombel. A bibliographical review of classical equations of state has therefore been carried out and has shown that semi-analytical equations of state such as the Noble-Able Stiffened Gas appear to be a good compromise in terms of accuracy and efficiency. First results on validation cases have been obtained using a homogeneous model taking into account non-condensable gases, by choosing for liquid water an extension of the NASG EOS, with temperature-dependent heat capacity Cp. Taking into account out-of-equilibrium effects, by correctly defining a time scale describing the return towards thermodynamic equilibrium, seems to be determining to get realistic results.
Another part of this work concerns the proposal of a new multifluid three-phase-flow model, designed to model phenomena such as steam explosion. The model has been built step by step in order to guarantee the existence of an entropy inequality. The non-conservative terms have been carefully defined, in order to ensure the uniqueness of the jump conditions. The final model is hyperbolic outside the resonance conditions.
Finally, some classical boundary conditions for the monophasic Euler system have been verified. An out-going rarefaction wave leaving the computational domain before the end of the simulation does not raise any issue with the classical conditions used in industrial codes; on the other hand, an out-going shock wave can lead to a numerical inconsistency, depending on the numerical scheme used and the boundary conditions adopted.
Cette thèse porte sur la modélisation et la simulation d’écoulements multiphasiques qui pourraient apparaître lors de scénarios accidentels pouvant hypothétiquement affecter un réacteur à eau pressurisée. Il s’agit d’écoulements principalement constitués d’eau, dont la phase gazeuse est composée d’un mélange miscible de gaz incondensables et de vapeur, et qui peuvent comprendre dans le cas de l’explosion vapeur une troisième phase immiscible formée par le corium fondu. Les modèles étudiés doivent être en mesure de simuler des transitions de phases très brutales, durant lesquelles l’eau liquide et l’eau vapeur sont susceptibles de persister de façon observable en dehors des conditions de l’équilibre thermodynamique. Différents aspects du processus de modélisation sont abordés dans ces travaux.
Dans un premier temps, on s’intéresse aux fermetures thermodynamiques à adjoindre aux modèles via la définition d’équations d’état phasiques admissibles les plus réalistes possibles. Un modèle homogène diphasique sans prise en compte des gaz incondensables a d’abord été fermé à l’aide une loi tabulée construite à partir de la formulation IAPWS-IF97. Puisque la table a été construite de façon à respecter la relation de Gibbs, la vérification du modèle via des études de convergence en maillage a pu être menée à bien. Ce travail a également souligné que la loi tabulée exigeait un schéma numérique de convection très robuste, tel que le schéma de relaxation proposé par C. Chalons et J.-F. Coulombel. Ces contraintes pratiques poussent à rechercher des lois d’état moins complexes à mettre en oeuvre numériquement. Une revue bibliographique de lois d’état classiques a donc été réalisée et a mis en évidence que les lois d’état semi-analytiques de type Noble-Able Stiffened Gas apparaissent comme un bon compromis en termes de précision et d’efficacité. Des premiers résultats sur des cas de validation ont pu être obtenus à l’aide d’un modèle homogène prenant en compte les gaz incondensables, en choisissant pour l’eau liquide une extension des lois NASG, avec capacité calorifique Cp dépendante de la température. Une bonne prise en compte des effets hors-équilibre, via la définition d’échelle de temps de retour vers l’équilibre thermodynamique, semble déterminante pour obtenir des résultats réalistes.
Une autre partie de ces travaux concerne la proposition d’un nouveau modèle triphasique multi-vitesse, destiné à modéliser les phénomènes de type explosion vapeur. Le modèle a été construit pas à pas de façon à garantir l’existence d’une inégalité d’entropie. Une attention particulière a été apportée à la définition des termes non-conservatifs, afin de garantir l’unicité des relations de sauts champ à champ. Le modèle final est hyperbolique en dehors des conditions de résonance.
Enfin, un travail transversal à la thèse a porté sur la vérification de conditions limites pour le système d’Euler monophasique. La sortie d’une onde de détente du domaine de calcul ne pose pas de problème avec les conditions classiques utilisées dans les codes industriels; en revanche, la sortie d’une onde de choc peut conduire à une inconsistence numérique, suivant le schéma numérique utilisé et les conditions limites adoptées.
