Emulation and prediction of cosmic web simulations through deep learning
Émulation et prédiction de simulations de la toile cosmique par apprentissage profond
The standard cosmological model provides a description of the Universe as a whole: its content, its evolution and its dynamics. A standard way of determining the evolution of matter in the Universe rests on the use of numerical simulations that are very expensive in terms of running time, storage and computing power. We explore the use of deep neural networks (DNN) as an alternative to these costly simulations. In a first part, we built and trained a Generative Adversarial Network (GAN) to extract the underlying distribution of a dataset, built from a simulated dark matter density field, and to quickly generate new simulation-like data with identical statistics. We have determined, in details, the strengths and limitations of use of GANs for this purpose, and found that the GAN successfully generates new images and data cubes that are statistically consistent with the data on which it was trained. In a second part, we have shown how to make use of the trained GAN to construct a simple replicative autoencoder (AE) that can conserve the statistical properties of the data, and further developed a predictive AE to infer data at redshift z=0 (today) from earlier epochs (z=1,2,3). We found that the replicative AE can efficiently extract information from simulation data to encode it into a reduced number of parameters. By this means, the AE can recover the images and cubes satisfactorily, notably conserving their statistical properties in terms of density distribution, power spectrum and peak counts. Finally, we show that the predictive AE, while showing poor predictive capacity in its simplest form, succeeds very well to infer data evolution once we supply it with sufficient information in input, notably when using the associated velocity field. With these proofs of concept, we conclude that DNNs are promising tools to quickly generate realistic large datasets. Moreover, when trained and supplied with the right information (e.g. dynamics of the density field) DNNs contain the necessary information to describe the structure evolution.
Le modèle cosmologique standard fournit une description de l'Univers dans son ensemble : son contenu, son évolution et sa dynamique. Une façon habituelle de déterminer l'évolution de la matière dans l'Univers repose sur l'utilisation de simulations numériques qui sont très coûteuses en termes de temps d'exécution, de stockage et de puissance de calcul. Nous explorons l'utilisation de réseaux neuronaux profonds (DNN) comme une alternative à ces simulations coûteuses. Dans une première partie, nous avons construit et entraîné un réseau antagoniste génératif (GAN) pour extraire la distribution sous-jacente d'un ensemble de données, construit à partir d'un champ de densité de matière noire simulé, et pour générer rapidement de nouvelles données de type simulation avec des statistiques identiques. Nous avons déterminé, en détail, les forces et les limites de l'utilisation des GAN à cette fin, et constaté que le GAN génère avec succès de nouvelles images et de nouveaux cubes de données qui sont statistiquement cohérents avec les données sur lesquelles il a été entraîné. Dans une deuxième partie, nous avons montré comment utiliser le GAN entraîné pour construire un autoencodeur (AE) réplicatif simple qui peut conserver les propriétés statistiques des données, et nous avons développé un AE prédictif pour déduire les données à z=0 (aujourd'hui) à partir des époques précédentes (z=1,2,3). Nous avons constaté que l'AE réplicatif peut extraire efficacement des informations des données de simulation pour les encoder dans un nombre réduit de paramètres. Par ce biais, l'AE peut récupérer les images et les cubes de manière satisfaisante, en conservant notamment leurs propriétés statistiques en termes de distribution de densité, de spectre de puissance et de nombre de pics. Enfin, nous montrons que l'AE prédictif, bien que montrant une faible capacité de prédiction dans sa forme la plus simple, réussit très bien à inférer l'évolution des données dès lors que nous lui fournissons suffisamment d'informations en entrée, notamment en utilisant le champ de vitesse associé. Avec ces preuves de concept, nous concluons que les DNNs sont des outils prometteurs pour générer rapidement de grands ensembles de données réalistes. De plus, lorsqu'ils sont entraînés et qu'on leur fournit les bonnes informations (par exemple, la dynamique du champ de densité), les DNN contiennent les informations nécessaires pour décrire l'évolution de la structure.
Origin : Version validated by the jury (STAR)
