Integration of vision and force control for physical interaction with robotic manipulators - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2022
Intégration de la commande visuel et de la force pour l’interaction physique avec des manipulateurs robotiques
Combined vision/force arrangements are becoming more and more common in small and medium sized businesses as “Cobots” becomes more affordable. Cameras can provide a detailed description of the scene, whereas force sensing can provide local but highly precise information about the contact. However, due to the very different nature of these sensing modalities , obtaining an effective combined use is not straightforward. In this thesis we deal with the coupling of vision and force sensing leveraging their complementarity and allowing a robot manipulator to actively achieve compliant motion along the visual task directions. We have developed advanced control schemes with estimators that cope with the update rate discrepancy between the sensors. furthermore, we contribute to the dynamic model parameter retrieval for manipulators, which are key ingredients both in the proposed controllers, whose take into account the manipulator’s dynamics, as well as for performing more accurate simulations. The reported results, both in the developed simulator and with real experiments show the effectiveness of the proposed techniques.
Dispositions combinées vision/force deviennent de plus en plus courants dans les petites et moyennes entreprises à mesure que les “Cobots” deviennent plus abordables. Caméras peuvent fournir une description détaillée de la scène, tandis qu’un capteur de force fournis des informations locales mais très précises sur le contact. Cependant, en raison de la nature très différente de ces modalités de détection, il n’est pas simple d’obtenir une utilisation combinée efficace. Dans cette thèse, nous traitons du couplage de la vision et de la détection de la force en tirant parti de leur complémentarité et en permettant à un robot manipulateur de réaliser activement un mouvement conforme aux directions de la tâche visuelle. Nous avons développé des schémas de contrôle avancés avec des estimateurs qui gèrent la différence de taux de mise à jour entre les capteurs. De plus, nous contribuons à la récupération des paramètres du modèle dynamique pour les manipulateurs, qui sont des ingrédients clés à la fois dans les contrôleurs proposés, qui prennent en compte la dynamique du manipulateur, ainsi que pour effectuer des simulations plus précises. Les résultats rapportés, tant dans le simulateur développé que dans les expériences réelles, montrent l’efficacité des techniques proposées.
OLIVA_Rainbow_thesis_2022.pdf (26.67 Mo) Télécharger le fichier
tel-03690426 , version 1 (08-06-2022)
tel-03690426 , version 2 (10-06-2022)
  • HAL Id : tel-03690426 , version 1
Alexander Oliva. Integration of vision and force control for physical interaction with robotic manipulators. Robotics [cs.RO]. Université Rennes 1, 2022. English. ⟨NNT : ⟩. ⟨tel-03690426v1⟩
199 Consultations
63 Téléchargements
