Lead-free Piezoelectric Microgenerator for Energy Autonomous Wireless Sensors - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2022
Microgenerateurs piezoelectriques sans plomb pour capteurs autonomes sans fils
The overall aim of this PhD work is the investigation of the harvest of power from ambient vibrations at relatively low frequencies < 500 Hz using lead free piezoelectric materials in order to power low power sensors or actuators that are used in the “Internet of things” IOT networks. The rapid growth of communication and information Technology (IT), along with the progress in the semiconductor industry in recent times, has generated growing interest in the field of IoT. The IOT concept comprises of “Smart Structures” with autonomous self-powered sensors, actuators and associated low-power electronics circuits that is spread across a network of wireless sensor nodes (WSNs) that can sense and share data among one another and the master unit. In order to make it fully autonomous it is very important that they are powered independently and therefore it is challenging to replace the depleted energy in the batteries. In this situation, the use of ubiquitous ambient mechanical vibrations to generate electricity for powering the WSNs is a promising choice.Among the various transduction mechanisms to convert vibrational energy to electric energy, piezoelectric transduction has drawn considerable attention because of its simplicity in structure, high energy density and good compatibility with micro/nano fabrication techniques. However, the mostly used high performing piezoelectric ceramics such as Lead Zirconate Titanate (PZT) contains lead which is hazardous. Recently, the European Union has also implemented the Restriction of Hazardous Substances legislation, that has set a strict standard restricting the use of lead-based piezoelectric materials in future electronic devices. This thesis will therefore investigate about novel lead-free materials as a potential candidate for high performance energy harvesting devices. This thesis begins with the basic introduction to the energy harvesting at microscale to power IOT nodes, followed by the chapter on piezoelectric materials and the extraction of their basic properties in order to develop devices. In the next chapter, fabrication and characterization of lead free piezoelectric energy harvester is described, followed by the application of such devices in real time sensing. The thesis focusses on the investigation of lead-free piezoelectric materials such as Sodium Potassium Niobate, Lithium Tantalate and Lithium Niobate as a potential candidate for energy harvesting applications. A brief discussion on processing and deposition of these piezoelectric materials to function as energy harvesting devices is also presented. Various techniques that have been used to characterize the electromechanical piezoelectric properties, morphologies such as Atomic Force Microscopy are typical examples of those techniques. The extracted electromechanical properties are compared with the state of the art in the literature. The fabrication and characterization of a lead free microgenerator based on lead free Lithium Niobate wafer is described. Also, the voltage conditioning circuit for ensuring controlled and stable DC output is discussed. An efficient architecture for the maximum power transfer (MPPT) from the piezoelectric harvester to load is proposed. The piezoelectric harvester demonstrated excellent ability in sensing and energy harvesting. The piezoelectric Harvester was demonstrated to power an Energy Autonomous Wireless Vibration Sensor EAWVS vibration sensor, that could be used for condition monitoring in automobile, heavy machineries, motors and so on. The EAWVS provides the added flexibility, that allows the measurement readout remotely and wirelessly by exploiting the Bluetooth Low Energy BLE communication and transmitting beacons at a remote BS with the sensor reading based on the easy-to-implement time-domain readout by measuring the advertising time Tadv. Finally, a brief summary into future prospective is discussed.
L'objectif global de ce travail de thèse est l'étude de la récolte de puissance des vibrations ambiantes à des fréquences relativement basses < 500 Hz en utilisant des matériaux piézoélectriques sans plomb afin d'alimenter des capteurs ou des actionneurs de faible puissance utilisés dans les réseaux IOT (Internet of Things). Le concept IOT comprend des « structures intelligentes » avec des capteurs autonomes, des actionneurs et des circuits électroniques à faible consommation associés répartis sur un réseau de nœuds de capteurs sans fil (WSN) capables de détecter et de partager des données entre eux et avec l'unité maître. Afin de le rendre totalement autonome, il est très important qu'elles soient alimentées indépendamment et il est donc difficile de remplacer l'énergie épuisée dans les batteries. Dans cette situation, la récolte de vibrations mécaniques ambiantes omniprésentes en utilisant des transducteurs piézoélectriques, pour générer de l’électricité pour alimenter les WSN est un choix prometteur. Cependant, les céramiques piézoélectriques hautes performances les plus utilisées, telles que le Titanate de Zirconate de Plomb PZT, contiennent du plomb qui est dangereux. Récemment, l'Union européenne a également mis en œuvre la législation sur la restriction des substances dangereuses, qui a établi une norme stricte restreignant l'utilisation de matériaux piézoélectriques à base de plomb dans les futurs appareils électroniques. Cette thèse étudie donc de nouveaux matériaux sans plomb en tant que candidats potentiels pour des dispositifs de récupération d'énergie à haute performance. Cette thèse commence par l'introduction de base à la récupération d'énergie à micro-échelle pour alimenter les nœuds IOT, suivie du chapitre sur les matériaux piézoélectriques et l'extraction de leurs propriétés de base afin de développer des dispositifs, suivi de l'application de tels dispositifs à la détection en temps réel. La thèse se concentre sur l'étude de matériaux piézoélectriques sans plomb tels que le niobate de sodium et de potassium, le tantalate de lithium et le niobate de lithium en tant que candidats potentiels pour des applications de récupération d'énergie. Une brève discussion sur le traitement et le dépôt de ces matériaux piézoélectriques pour fonctionner comme des dispositifs de récupération d'énergie est également présentée. Diverses techniques qui ont été utilisées pour caractériser les propriétés piézoélectriques électromécaniques, des morphologies telles que la microscopie à force atomique sont des exemples typiques de ces techniques. Les propriétés électromécaniques extraites sont comparées à l'état de l'art de la littérature. La fabrication et la caractérisation d'un microgénérateur sans plomb à base de plaquette de lithium niobate sans plomb sont décrites. En outre, le circuit de conditionnement de tension pour assurer une sortie CC contrôlée et stable est discuté. Une architecture efficace pour le transfert de puissance maximale (MPPT) du récupérateur d’énergie à la charge est proposée. Il peut être utilisé pour alimenter un capteur de vibrations sans fil autonome en énergie (Energy Autonomous Wireless Vibration Sensor-EAWVS). Les applications concernent la surveillance de l'état dans les automobiles, les machines lourdes et les moteurs, etc. L'EAWVS offre une flexibilité supplémentaire, qui permet la lecture de mesure à distance et sans fil en exploitant le Bluetooth Communication (Bluetooth Low Energy-BLE) basse consommation et balises émettrices sur une BS distante avec la lecture du capteur basée sur la lecture facile à mettre en œuvre du domaine temporel en mesurant le temps publicitaire (advertising Time, Tadv). Enfin, un bref résumé de la prospective future est discuté.
PANAYANTHATTA_2022_archivage.pdf (9.58 Mo) Télécharger le fichier
tel-03702754 , version 1 (23-06-2022)
  • HAL Id : tel-03702754 , version 1
Namanu Panayanthatta. Lead-free Piezoelectric Microgenerator for Energy Autonomous Wireless Sensors. Micro and nanotechnologies/Microelectronics. Université Grenoble Alpes [2020-..], 2022. English. ⟨NNT : 2022GRALT017⟩. ⟨tel-03702754⟩
273 Consultations
132 Téléchargements
