De l'héritage épistémologique de Paul Otlet à une théorie relationnelle de l'organisation des connaissances. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2022
From Paul Otlet’s epistemological legacy to a relational theory of knowledge organization
This dissertation examines the relationship between intellectual work and the tools thereof, through a study of the epistemological legacy of Paul Otlet (1868-1944), the first theorist of documentation. It addresses the problem of scholarly knowledge organization and management from the perspective of personal documentation. It represents both theoretical work in documentology and knowledge organization, and reflexive work based on designing and using a document graph visualization tool named Cosma. Through the analysis of Otlet’s writings, diagrams and documentary realizations, we establish that the network principle he proposes does not apply only to institutions but also to documents themselves. We follow W. Boyd Rayward’s hypothesis, which has never been properly tested, of a parallel between the fundamental components of Otlet’s work (monographic principle, universal decimal classification) and those of hypertextual systems (nodes, links). We empirically verify this parallel by describing the realizations of the HyperOtlet research programme, and we generalize Rayward’s idea to the notion of graph, putting forward the elements of a relational theory of knowledge organization. We characterize the epistemology of hypertextual personal documentation as reflexive and heuristic: representating a graph highlights the reticular nature of the writing and thought processes behind it; the representation serves as a memory aid and supports information surfacing. We discuss the concept of cosmography as the ordering of an intellectual universe through writing, bridging the concepts of idiotext (writing as singular prosthetic memory), hypertext (reticular writing) and architext (writing of writing).
Cette thèse porte sur la relation entre le travail intellectuel et son outillage, à travers une étude de l’héritage épistémologique de Paul Otlet (1868-1944), le premier théoricien de la documentation. Elle traite du problème de l’organisation et de la gestion des connaissances savantes sous l’angle de la documentation personnelle. Il s’agit à la fois d’un travail théorique en documentologie et en organisation des connaissances, et d’un travail réflexif basé sur la conception et l’utilisation d’un outil de visualisation de graphe documentaire nommé Cosma. À travers l’analyse des écrits, schémas et réalisations documentaires d’Otlet, nous établissons que la logique de réseau qu’il propose n’est pas seulement de nature institutionnelle mais qu’elle s’applique également aux documents eux-mêmes. Nous reprenons une hypothèse émise par W. Boyd Rayward, jamais réellement éprouvée, qui consiste à établir un parallèle entre les composants fondamentaux du travail d’Otlet (principe monographique, classification décimale universelle) et ceux des systèmes hypertextuels (nœuds, liens). Nous vérifions empiriquement ce parallèle en nous appuyant sur les réalisations du programme ANR HyperOtlet, et nous le généralisons à la notion de graphe pour proposer les éléments d’une théorie relationnelle de l’organisation des connaissances. Nous caractérisons l’épistémologie de la documentation personnelle hypertextuelle comme réflexive et heuristique : la représentation du graphe met en évidence la nature réticulaire de certains processus d’écriture et, par-là, de pensée ; elle sert d’aide-mémoire, avec une logique d’émergence informationnelle. À partir de ce travail, nous proposons la notion de cosmographie comme mise en ordre d’un univers intellectuel par l’écriture, entre idiotexte (écriture comme mémoire prothétique singulière), hypertexte (écriture réticulaire) et architexte (écriture de l’écriture).
These_Arthur_PERRET.pdf (13.83 Mo) Télécharger le fichier
tel-03954967 , version 1 (24-01-2023)
  • HAL Id : tel-03954967 , version 1
Arthur Perret. De l'héritage épistémologique de Paul Otlet à une théorie relationnelle de l'organisation des connaissances.. Sciences de l'information et de la communication. Université Michel de Montaigne - Bordeaux III, 2022. Français. ⟨NNT : 2022BOR30017⟩. ⟨tel-03954967⟩
259 Consultations
290 Téléchargements
