Machine Learning-Enabled Network Traffic Analysis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2022
Analyse du trafic réseau basée sur l’apprentissage automatique
Recent development in network communication along with the drastic increase in the number of smart devices leads to an explosion in data generation. To this end, intelligent network traffic analysis can help to understand the behavior of connected smart devices and applications as well as provides defense against cyber-attacks. In this line, Machine Learning (ML) and Deep Learning (DL) models have the ability to model and uncover hidden patterns using training data or environment. Despite their benefits, major challenges need to be addressed such as model generalization (due to model overfitting), lack of label (due to the difficulty to label all the data), and privacy (due to recent regulations). In this thesis, new ML/DL-based models are proposed for tackling these challenges. The first contribution focuses on improving the generalization and classification performance by proposing an ensemble blending model. The simulation results show that the accuracy of the proposed ensemble model is 10%, better than some state-of-the-art models. Second, a semi-supervised model has been proposed and the experiment results show that unlabeled data boost the classification accuracy by 11% in comparison to its supervised version. Finally, a Federated Learning (FL) based Intrusion Detection System (IDS) has been proposed. It allowed the clients to learn an efficient intrusion detection model without the need to label their local data as well as to achieve high classification performance and improvement in terms of communication overhead (reduction by almost 75% in comparison to a centralized model).
L’Internet des Objets entraînent par son nombre de terminaux une explosion du trafic de données. Pour augmenter la qualité globale de réseau, il est possible d’analyser intelligemment le trafic réseau afin de détecter d’éventuel comportement suspect ou malveillant. Les modèles d’apprentissage automatique et d’apprentissage profond permettent de traiter ce très grand volume de données. Néanmoins, il existe certaines limites dans la littérature, notamment la confidentialité des données, le sur-apprentissage (manques de diversité dans les données) ou tout simplement le manque de jeu de données labélisées. Dans cette thèse, nous proposons de nouveaux modèles s’appuyant sur l’apprentissage automatique et l’apprentissage profond afin de traiter une grande quantité de données tout en préservant la confidentialité. Notre première approche utilise un modèle d’ensemble. Les résultats montrent une diminution du sur-apprentissage, tout en augmentant de 10% la précision comparé à des modèles de l’état de l’art. Notre seconde contribution s’attache aux problèmes de disponibilité des données labélisées. Nous proposons un modèle d’apprentissage semi-supervisé capable d’améliorer la précision de 11% par rapport à un modèle supervisé équivalent. Enfin, nous proposons un système de détection d’attaque s’appuyant sur l’apprentissage fédéré. Nommé FLUIDS, il permet de réduire la surcharge réseau de 75% (comparé à son équivalent centralisé) tout en préservant de très haute performance et la confidentialité.
PhD_thesis_final_version.pdf (17.2 Mo) Télécharger le fichier
tel-03966012 , version 1 (09-01-2023)
tel-03966012 , version 2 (31-01-2023)
  • HAL Id : tel-03966012 , version 1
Ons Aouedi. Machine Learning-Enabled Network Traffic Analysis. Computer Science [cs]. Nantes Université, 2022. English. ⟨NNT : ⟩. ⟨tel-03966012v1⟩
708 Consultations
102 Téléchargements
