Embedding models for relational data analytics
Modèles d'embedding pour l'analyse de données relationnelles
Analytical pipelines, such as those relying on machine learning models, typically require data in the form of a single table describing the entities under study with a fixed set of attributes or features. In practice however, data often come as relational data (e.g. relational databases or knowledge graphs), where information on the entities of interest is irregular and scattered across sources. To leverage this relational data, it must thus be assembled into a format suitable for analysis, which requires time and expertise from the analyst. As an alternative, we investigate in this thesis the potential of embedding models to facilitate relational data assembling. We especially consider two data integration problems: 1) entity matching (e.g. linking "Paris" and "Paris, FR") when dealing with non-normalized data sources that have different knowledge-representation conventions; and 2) feature engineering over relational data to enrich data analyses with background information. Finally, we show that embedding models are indeed promising tools for relational data analytics: 1) "good" vectorial representations (a.k.a. embeddings) of entities can replace manual entity matching without hindering the quality of subsequent analyses; and 2) entity embeddings learned directly over relational data can automate feature engineering in an efficient and scalable way, paving the way for general-purpose representations that can bring background information in various downstream tasks.
L'analyse de données, par exemple via des modèles d'apprentissage automatique, requiert généralement qu'elles soient regroupées en une table unique décrivant les entités analysées par un nombre fixe d'attributs ou features. En pratique cependant, la plupart des jeux de données sont relationnels (cf. bases de données relationnelles et graphes de connaissance), où l'information sur les entités d'intérêt est irrégulière et dispersée à travers plusieurs sources. Pour analyser de telles données, il est alors nécessaire de les assembler dans une structure unique (généralement une table), ce qui demande du temps et de l'expertise. À la place, nous étudions dans cette thèse le potentiel des modèles d'embedding pour faciliter l'assemblage et l'intégration de données relationnelles. Nous nous intéressons particulièrement aux deux problèmes suivants : 1) l'appariement d'entités (par exemple "Paris" et "Paris, FR"), qui est souvent nécessaire lorsque les données proviennent de sources ayant des manières différentes de représenter la même information ; et 2) le feature engineering sur des données relationnelles pour enrichir l'analyse de données avec de l'information externe. Enfin, nous montrons que les modèles d'embedding sont des outils prometteurs pour l'analyse de données relationnelles : 1) utiliser de "bonnes" représentations vectorielles (i.e. embeddings) d'entités peut remplacer l'appariement manuel d'entités, sans compromettre la qualité des analyses en aval ; et 2) apprendre des embeddings d'entités directement sur des données relationnelles est un moyen efficace et applicable à de grands jeu de données d'automatiser le feature engineering. Ceci ouvre la voie vers l'apprentissage de représentations généralistes d'entités, facilement utilisables dans de nombreuses applications.
Origin : Version validated by the jury (STAR)
