Matings of complex polynomials
Accouplements des polynômes complexes
Let f and g be two monic quadratic complex polynomials. Take two copies of the complex plane C and compactify them by adding a cercle at the infinity, then sew up these two cercles to make a topological sphere S2 . Get f and g mapping on each hemisphere of S2 . We obtain a mapping F from S2 to its self. It's a branched covering and we call it a topological mating of f and g.
The union of the orbits by F of the critical points of F is defined to be the postcritical set of F. Thurston defined an equivalence between postcritically finite branched coverings of S2 . Suppose that f and g are postcritically finite. We say that f and g can be mated if F (modified in some cases) is equivalent to a rational function. If f and g can be mated, then we can obtain the sphere S2 by sewing up the boundaries of the filled in Julia sets of f and g .
Quadratic polynomials with bounded postcritical set are paramelized by the Mandelbrot set M. Let W be the closure of the principal component of the interior of M. If the parameters of f and g are in conjugate components of M-W, then f and g cannot be mated. Douady and Hubbard conjectured that they can be mated in all other cases. We prove this conjerture in this thesis by using a criterion of Thurston, and by supporting on the works of Silvio Levy and of Mary Rees.
This result can be generelized to polynomials of greater degree but having only one critical point.
Soient f et g deux polyñomes quadratiques complexes moniques.
On prend deux exemplaires du plan complexe, on les compactifie en ajoutant un cercle à l'infini, on recolle ces deux cercles et on obtient une sphère toplogique S . En faisant opérer f et g sur chacun des hémisphères, on peut obtenir une application F de S dans elle même. C'est un revêtement ramifié qu'on appelle l'accouplement topologique de f et g.
La réunion des orbites directes par F des points critiques est l'ensemble postcritique de F. Thurston a défini une équivalence entre revêtements ramifiés à ensemble postcritique fini. On dit que f et g sont accouplables si F (modifié dans certains cas) est équivalent au sens de Thurston à une fraction rationnelle. Si f et g sont accouplables, on peut obtenir la sphère en collant les ensembles de Julia remplis de f et g. Les polynômes quadratiques à ensemble postcritique borné sont paramétrés par l'ensemble de Mandelbrot M. Soit W l'adhérence de la composante principale de l'intérieur de M. Si les paramètres de f et g sont dans des composantes conjuguées de M-W , alors f et g ne sont pas accouplables. Douady et Hubbard ont conjecturé qu'ils sont accouplables dans tous les autres cas. Nous démontrons ici cette conjecture, en utilisant le critère de Thurston, et en nous appuyant sur les travaux de Silvio Levy et de Mary Rees.
Ce résultat s'étend aux polynômes de degré quelconque ayant un seul point critique.
